585,778 active members*
4,326 visitors online*
Results 1 to 6 of 6
    Jun 2012
    20
    mach3 limitations?
    i have been told that i am running programs that are to big to run in mach 3. i was not given a specific reason as to why this would be an issue. so im trying to figure out what can be done ,if this is even a thing. am i limited by the software or the computer?
    Jun 2005
    1730
    Re: mach3 limitations?
    How big is your Gcode file? How many lines. A licensed version of Mach3 can run really big gcode files, the unlicensed version is only good for 500 lines of gcode.
    I think that mach3 can run programs up to 10 million lines. With really large files, Mach3's toolpath display can use a lot of resources and affect mach3 operation. If that happens, you can simply turn off the toolpath display, and then large files will run the same as small files.
    Jun 2012
    20
    ok, so 4 to 5 million lines shouldnt cause problems? as long as the tool path is off
    Aug 2004
    780
    Most problems are video-card related.
    Good video cards are much better.
    64 bit is much better.
    Faster processor is much better.
    I cannot recommend a video card.
    I use an Industrial Nvidia Quadro 2000, 5 yo, and this is likely overkill.
    Mach3 as such is perfectly stable, and runs, easily, 10M line programs for me.
    They take maybe 30 secs to load.
    I use toolpaths- zero issues.
    But the video card is determinant.
    The video issues are related to Win + M3 architecture, and will not change.
    Mach4 will not have the same problems.
    Jun 2012
    20
    Quote Originally Posted by hanermo View Post
    thank you, very helpful hanermo
  1. Limitations of Fusion 360
    By naytep in forum Autodesk CAM
    Last Post: 03-14-2016, 01:26 PM
  2. So many limitations
    By pp-TG in forum BobCad-Cam
    Last Post: 09-12-2013, 12:28 AM
  3. 4-axis limitations?
    By OC_ in forum FeatureCAM CAD/CAM
    Last Post: 05-17-2007, 02:43 PM
  4. THK SR type limitations
    By NC_jimbo in forum Linear and Rotary Motion
    Last Post: 04-19-2007, 02:25 PM
  5. DC motor limitations
    By rippersoft in forum RC Robotics and Autonomous Robots
    Last Post: 09-08-2005, 02:58 AM
