I'm running fusion 360. I have DNC4U program to send program codes to the machine. Anyone have any experience or tips? I have taken the factory amphenol connection off and replaced it with a serial DB9 cable and hooked the wires up as per hurco website. I do not know if it is a NUL type serial cable or not which it very well might be my problem. I'm not able to send anything to the machine. Any tips on the setting in the controller or tips on what post processor to use through fusion 360 would be appreciated. I'm currently using the Hurco3d post which is supposed to be for the older hurco machines. You can shoot me a txt or call if you can help. Four zero 9 two hundred 9 7 five seven
