585,996 active members*
4,923 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > Can I use the cps file in PowerMill
    Jan 2017
    I'm looking for the post processor for my CNS (a mach3 machine), and I seached the Post Library in autodesk (Autodesk CAM | Post Library) and found a Gereric Mach3Mill file from ArtSoft. However, this file is a cps file, which cannot be used in PowerMill (pmoptz is expected).
    May I know where I can find the post processor for Mach3 machine? Or can I use this cps file in PowerMill, if so, how?
    Besides, someone give me a mach3 post file with extension .opt, which is a post file for old version PowerMill, is there any tools to convert the file to pmoptz format?
    Thanks in advance.
    Oct 2008
    13
    Re: Can I use the cps file in PowerMill
    In Delcam PostProcessor > file>import you can open *.opt an save it to *.pmoptz, and do some edits for your needs,
  1. powermill
    By pasha0 in forum PowerMILL
    Last Post: 08-19-2014, 11:51 AM
  2. PowerMill Robot Post & .mtd File
    By joepower in forum Post Processor Files
    Last Post: 11-23-2013, 12:23 PM
  3. Replies: 0
    Last Post: 08-30-2013, 07:21 AM
  4. Delcam powermill pro 8 : tap file output
    By axis_control in forum Engraving Machines
    Last Post: 11-05-2009, 05:59 AM
  5. PowerMill and 2D
    By georgebarr in forum Uncategorised CAM Discussion
    Last Post: 03-31-2004, 05:56 PM
