585,762 active members*
4,263 visitors online*
IndustryArena Forum > CAM Software > CamBam > Cambam toolpath problem
Results 1 to 9 of 9
    Jan 2017
    9
    Hello there,
    I'm a newby on this cnc and camcad but i will get to it with a bit of perceverance and the help of this forum.
    Please see attached screenshots
    The object is in red and in blue is the toolpath, the intriging thing are the 2 arcs cercled in red that the toopath shows that the tcutting tool went inside the object.
    Is this something grong in my setting, if you note thatthese are the only 2 inside arcs all the others arcs are ok !!
    Dec 2013
    5717
    Re: Cambam toolpath problem
    You have a broken polyline. Make sure the polyline is continuous and that there is not one arc over the top of the other.
    Jan 2017
    9
    Thanks Jim
    How can i check that and how can i fix it
    Dec 2013
    5717
    Select that arc and see if it's connected to the other parts of the profile. It it's not connected, select the entire profile, then right click, edit, and join .That should fix it.
    Aug 2016
    7
    Given the inside corners where the toolpaths cross over to the other side, it could be that corner overcut is turned on for that toolpath.
    Jan 2017
    9
    Done as above but still no joy
    - - - Updated - - -
    corner overcut is off!!!
    Dec 2013
    5717
    Can you upload your .cb file? Upload it with a .txt extension to be compatible with the forum software.
    Jan 2017
    9
    Hello everyone,
    I managed to get further with Cambam, but now I do get an understendable glitch once I generate toolpath with Cambam it looks great and producea gcode.
    Once the gcode is loaded in mach3 the display only shows only one cutout in this case the circle on top of the frame.
    Please see enclosed photo.
    In this instance I decided to generate a profile for outside cutout and one profile for the inside cutout, for the outside cutout it works fine but not the inside cutout.
    Hope some can clarify this for me
    Thans again
    Dec 2013
    5717
    It looks fine on my screen in Mach3, not sure what the problem is. But I'm not an expert in Mach3
  1. CamBam toolpath generation issue
    By ctilley79 in forum CamBam
    Last Post: 01-29-2013, 05:26 AM
  2. CamBam engraving problem
    By jakuba in forum CamBam
    Last Post: 11-06-2012, 07:55 AM
  3. Cambam problem
    By crodriguez1517 in forum CamBam
    Last Post: 08-05-2012, 04:04 AM
  4. CamBam 3D problem still bothering!
    By kievari in forum CamBam
    Last Post: 08-08-2011, 09:46 AM
  5. cambam problem
    By smitty9306 in forum CamBam
    Last Post: 10-04-2009, 05:43 AM
