PIN
X MINUS TO X203 n/c switch
X PLUS TO X204 n/c switch
Y MINUS TO X205 n/c switch
Y PLUS TO X206 n/c switch
Z MINUS TO X207 n/c switch
Z PLUS TO X208 n/c switch
X HOME TO X111 NPN sensor
Y HOME TO X112 NPN sensor
Z HOME TO X113 NPN sensor
E STOP TO X110
Running Mach 4 Demo Warp 9 M62 BOB and ESS
no A axis as yet connected and spindle running as stand alone
all X Y Z axis work ok
But having problems with homing on XYZ
All home sensors have lighst on and when I move a metal object
over the sensor the red light on the board goes out also
I checked the 24volt feed to the sensors which is ok and when I trip the sensor it
goes to zero voltage also when the bed moves over the homing sensor
I get an alert that the home has been tripped but the axis still keeps moving
any ideas
