585,582 active members*
3,783 visitors online*
Results 1 to 6 of 6
    Sep 2016
    Additional inputs with UC100
    I have the UC100 controller and I would like to implement an MPG, FRO, SRO and so on for a control panel.
    Can I add a LPT to usb converter and use it as port 2 (or any other port number)? My guess would be no.
    Can I use an arduino as an interface and use Modbus?
    Or do I have to buy a UC300ETH?
    Thanks!
    Apr 2013
    1899
    Re: Additional inputs with UC100
    No, you can't use an LPT port. UCCNC does not support the parallel port, not even if it is a USB - LPT converter.
    Yes, you can use Modbus but make sure it is REAL Modbus. UCCNC does have a Modbus plugin and that works well.
    Buying a UC300ETH would be the simplest solution, but you need a license. I don't think you can "give back" the UC100 license and exchange to UC300ETH.
    How would you assign inputs from a Modbus device in UCCNC?
    Apr 2013
    1899
    I guess the same way as the VFD inputs.
    Feb 2008
    482
    Quote Originally Posted by kaptronik View Post
    Thanks!
    Yes you can use arduinos- I tested 2 running perfectly for a week
    so much to learn, so much to pass on.
    Oct 2005
    1145
    Teh modbus READS are brought out to teh assigned Modbus Variables table and from there you use a MacroLoop to move them where ever you need them.
    (;-) TP
  1. Question about using UC100
    By gene8522 in forum UCCNC Control Software
    Last Post: 01-30-2017, 03:41 PM
  2. UC100
    By naijin in forum Australia, New Zealand Club House
    Last Post: 02-01-2016, 04:04 PM
  3. Mach & Additional IOs
    By aus-newb in forum Mach Lathe
    Last Post: 12-18-2006, 05:07 PM
  4. Additional forum
    By HuFlungDung in forum Uncategorised MetalWorking Machines
    Last Post: 03-04-2003, 02:52 AM
