I'm running a Ballard VTL driven by a FANUC 18-T. I'm having issues with the work offset. When I go to touch my tool to the work piece, then go to offset settings and scroll to W.Shift, I get the (Shift Value) and(Measurement). From what I'm used to, you only use measure to get your part ZEROS. WELL,when I touch off, select the axis on the (measure side) then type 0, I get some bogus numbers on the (shift value) side. On top of that, if I do a G28 return to home, it goes to my part zeros before returning home(potentially wiping out the part if my tool isn't above the part. Any help would be greatly welcome. Haven't ran a FANUC Control in quite awhile.
