585,557 active members*
3,213 visitors online*
    Feb 2017
    11
    nc stuido fault codes
    at the moment and I'm using a friends Chinese cnc running nc studio (I'm used to mach 3), its cutting OK however its running on nc studio that I'm not used to and we keep on getting a fault codes come up and I can't find much on the internet about them. I Java attached a picture of the screen with them on if anyone has any suggestions? It seams to happen every time we have the machine running for a few hours. does any one have any ideas on were to start?
    many thanks
    Dec 2005
    592
    Re: nc stuido fault codes
    Looks like your G Code files have errors in them. The three red X's indicate there are missing parameters for whatever they are trying to do. Can't tell the full extent since the error lines are cut off before we can see all of the error line.
  1. Mazak CNC Mill VTC -16B Fault Codes, won't start.
    By eku93 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-04-2014, 02:24 AM
  2. Mazak CNC Mill VTC -16B. Fault Codes, won't start.
    By eku93 in forum DNC Problems and Solutions
    Last Post: 09-01-2014, 11:46 PM
  3. Mazak CNC Mill VTC -16B Fault Codes won't start.
    By eku93 in forum CNC Machine Related Electronics
    Last Post: 09-01-2014, 11:32 PM
  4. Need full list of G CODES AND M CODES FOR FANUC 21I
    By SonnyTees.com in forum G-Code Programing
    Last Post: 02-23-2010, 05:27 PM
  5. Fanuc 0T/0M fault codes and Manuals
    By Al_The_Man in forum Fanuc
    Last Post: 11-27-2009, 06:58 PM
