585,978 active members*
4,438 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Mdf 18mm cutting setting for 5 minutes
    Hi my name is marcus, i'm new user of cnc router for mdf wood like this image, size 1.22m x 2.44m thickness 18mm, right now i'm using rpm 18.000, stepdown 4mm second, feedrate 15mm/second, too slow, only 4 piece a day, and the router bit easily to broke, so need help, here is my questions
    What is the setting for these? material thickness 18mm
    1. spindle rpm speed?
    2. Step down mm/second?
    3. Feedrate mm/second?
    4. what kind of Router bit ?
    Hope you can help me
    Thank you very much
    Re: Mdf 18mm cutting setting for 5 minutes
    What kind of machine do you have?
  1. Replies: 0
    Last Post: 03-28-2016, 04:54 AM
  2. use laser cutter to cut 18mm plywood
    By Nolan Yang in forum Videos
    Last Post: 09-02-2015, 04:02 AM
  3. Replies: 0
    Last Post: 05-06-2014, 02:41 AM
  4. Spindle+VDF recommendation for long jobs cutting 18mm Plywood below €1000
    By javito in forum DIY CNC Router Table Machines
    Last Post: 05-17-2013, 10:27 AM
  5. One out of 18mm MDF in the Netherlands
    By Witsenburg in forum CNC Wood Router Project Log
    Last Post: 07-08-2007, 08:20 PM
