585,877 active members*
3,273 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Looking for help to decide CNC or 3D printing.
Results 1 to 8 of 8
    Feb 2017
    5
    Hello all,
    I am trying to start a business with a frined in plastic miniatures on 28mm scale. This kind of miniatures http://www.1-72depot.com/wp-content/...99417427_o.jpg
    I am in the procces of building a simple cylinder/piston plastic injection machine and we have started developing the models in Blender.
    Now we are stuck with deciding which way to go regarding the mold making, we have thought about SLA 3D printers and CNC machines but we cannot find anything that will provide enough detail, and we don't know if it is a case of we are underestimating the capital needed or there isn't something at hobbyst/desktop level.
    We wouldn't have a problem on purchasing a 5000€ machine in Europe if there is one that can deliver this kind of quality.
    https://megabitzshop.com/bilder/prod...ren-Kopf-F.jpg
    As an example this head might be 5mm tall so we need an accuracy or resolution in the microns scale. So whatever surface we do is completely smooth and doesn't look like this. https://cdn.instructables.com/FVY/X0...RR7.MEDIUM.jpg
    Another problem we have found with CNC machines is that the plastic injection machine has to have an angle, so effectively those surfaces will look like stairs, so the better the resolution the straighter it looks rather than stairs like.
    Any help or recomendations would be appreciated.
    Dec 2013
    5717
    Re: Looking for help to decide CNC or 3D printing.
    The stairstep is a function of stepover and endmill shape. It is possible to achieve almost a mirror surface on any shape using a CNC machine with proper G-code and tooling.
    Feb 2017
    5
    Cool, if that is something that can be taken care of perfect.
    What machines are available in the 3000 to 5000€ in Europe? If you know any.
    Most of the good ones I have seen are in the US and import taxes will be almost 30% of the cost.....
    Dec 2013
    5717
    I don't know what machines are available in the EU. Given the resolution and accuracy you want, finding a machine in your price range might be difficult. That is not normally something you find in the hobby class machines. A used commercial machine might be your best option. If you can find one that is in mechanically good condition with bad controls, upgrading the controls is not that difficult expensive. I'm not sure if a stepper driven machine will give the resolution that you want, maybe if the motors are geared down it would work.
    EDIT:
    Maybe something like this?
    Feb 2017
    5
    The problem I see, and it might just be me from outside the industry is that there is no middle ground CNCs.
    You have desktop grade and instantly you jump at industrial 3 phase ones that are literally as tall as a human and cost 30000€
    35538
    $30000 is the middle ground.
    If you're trying to make something like the figures in your first link, then you're probably going to find that there are a lot of areas that the tool won't be able to reach, without a 5 axis machine.
    Also, you're going to need to use really small tools, and could possibly be looking at run times of 20 hours or more, if you want a really good finish.
    There's going to be a fairly steep learning curve here.
    Feb 2017
    5
    The miniature I put is an example, ideally all our models will be able to be machined in such a way that there are no negative angles that the CNC machine has to take care.
    In the following image I explain what I mean, the shape on the left can be done with a 3 axis machine, that will do the angles by stepping, the question is can a machine with a 3 micron step create a mirror surface while working on angled surfaces, or will it inevitable be visible and you will see the mold like this https://cdn.instructables.com/FVY/X0...RR7.MEDIUM.jpg
    The shape on the right is something that you will need a 5 axis machine, but that is not effective cause the piece that is injected won't be removable from the mold, so we would never do thing like those. It will be always positive angles.
    As for the time I am not worried, it is more a case of if I can do a mirror finish with those machines, even if doing the mold takes a week because I go at the slowest speed posible and take the smallest step possible.
    Jan 2019
    3
    I want to ask question about 3D printing .
    Can 3D printing be used in mechanical engineering ?
  1. Please help me decide!!!
    By Landon22 in forum Stepper Motors / Drives
    Last Post: 02-14-2015, 12:45 AM
  2. 3D Printing Live! Joining the ranks of the international 3D printing conferences
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-15-2013, 09:20 PM
  3. Help me decide
    By oknups in forum Tormach Personal CNC Mill
    Last Post: 02-23-2011, 06:52 PM
  4. Just trying to decide
    By Drools in forum Mini Lathe
    Last Post: 03-03-2010, 09:23 PM
