585,602 active members*
3,535 visitors online*
    Nov 2011
    260
    How to use 3D scanner --- There's a video
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
    Jul 2017
    22
    Re: How to use 3D scanner --- There's a video
    3D scanners collect information about objects within a set visual field, but unlike cameras, 3D scanners collect information about an object’s position in space instead of its color and appearance. This is possible by calculating the distances between the scanner and various points of an object’s surface.
    Normally, 3D scanners can be sorted into two different types: contact scanners and non-contact scanners.
    Contact scanners, as the name suggests, require direct contact with the object that they are scanning while non-contact scanners use laser light or radiation (such as X-ray or ultrasound) to gather information about the object.
  1. Anyone using USB Scanner/Camera with PathPilot (Scanner Function)?
    By ehpepper in forum Tormach PathPilot™
    Last Post: 04-27-2016, 09:01 PM
  2. Galvanometer Scanner/ Galvo Scanner
    By grace cao in forum Laser Hardware
    Last Post: 11-28-2013, 06:52 AM
  3. Video - DIY 3D Laser Scanner by Colin Ord
    By scan3d in forum 3D Printing / Scanning Software and Hardware
    Last Post: 02-03-2010, 06:45 AM
  4. Video of 3D scanner on utube.
    By Dan Mauch in forum 3D Printing / Scanning Software and Hardware
    Last Post: 04-26-2007, 02:02 AM
