1.What is fiber laser?
A fiber laser is a special type of solid state laser. Generally, fiber lasers are optically pumped. This is done by coupling the radiation of diode laseers or other fiber lasers into the cladding or the core itself in a direction parallel to the fibr
core. In many cases, double clad fibers are used in order to achieve higher output power.
What's material can fiber laser cut?
All kinds of metal, such as Stainless Steel,Carbon Steel, Mild Steel, Galvanized Steel, Aluminum, copper, etc.
2.Which fiber source does gweike applied?
IPG - Made in USA.
Raycus- Made in China;
Maxphotonics - Made in China;
3.What’s the different from fiber laser, YAG laser and CO2 laser working on metal material?
What is gweike Fiber laser advantages?
Fiber laser YAG laser CO2 laser Beam quality Best Good Poor Speed Fast Slow Slow Electrical efficiency High Common Low Reliability Best Good Poor Maintenance Free Complex Difficult Remote processing Free Complex Difficult Initial investment High Common Low
>Excellent beam quality (light-concentrating beam from optical fiber)
>Simple , compact, electrically and optically efficient (small footprint and low power consumption by fiber amplification)
>Compatibly powerful and reliable (realized by high brightness, high power semiconductor lasers as pumping light)
>Maintenance free (the entire optical fiber setups without lenses, mirrors)
>multilingual, more than 11 foreign languages
>3 years warranty .
4.What’s the function of fiber laser?
Fiber Laser is only used to cut metals like Stainless Steel, Carbon/Mild Steel, Galvanized Steel, etc. Non-metal is not ok.
5.. What's the max. cutting thickness?
Cutting thickness is related to laser power.
300W: 1.5mm stainless steel, 4mm carbon steel
500W: 3mm stainless steel, 6mm carbon steel
1000W: 5mm stainless steel, 12mm carbon steel
2000W: 10mm stainless steel, 18mm carbon steel
Note: only 1KW or above fiber laser could cut Aluminum, Copper, Brass and other high reflection sheet metal.
6.. What’s the brand of laser source?
<1KW: Raycus made in China or SPI / IPG made in Germany
≥1KW: Raycus/Maxphotonics/ IPG made in Germany
7. How to choose among different models?
1) Belt transmission with stepper motor for advertisement and light industries purpose, both 300 and 500W could be installed.
LF3015C: standard model with 300W
LF3015G: protection cover is added based on F2513C.
2) Ball screw with servo motor transmission
LF3015C: standard model with 500W
LF3015CR: pipe cutting function is added based on M3015C.
LF3015G: protection cover is added based onLF3015G.
3) Rack & Pinion with dual motors driving
LF3015C: standard model with 500W, 750W or 1000W
LF3015G: it’s equipped with double exchangeable table based on G3015C.protection cover is added based on G3015G
1. What kinds of laser machine do you have?
For industry purpose, there are many different laser sources for different laser application!
1)Fiber Laser Cutting Machine 3000W,2000W ,1000W,800W,500W,300W (LF,LM,LG series)Excellent Cutting Different Metal in different thickness
2)Metal & Non-metal Mixed CO2 Laser Cutting Machine 150W, 260W, 400w (LC series)
Cutting Thicker Acrylic, MDF, Wood and Metal material: stainless steel,carbon steel,iron sheet,galvanized sheet,etc;
3)Fast Flow CO2 Laser Die Board Cutting Machine 2000W,1500W,1000W, (LC series Flaten Die cutting machine & CD Rotary die cutting machine)
Cutting Thicker Die Board ,Wood MDF Acrylic,etc;
4)40W-150W CO2 Laser (WK and LG series)
Engraving and Cutting Non metallic material like Acrylic, Plastic, Wood, MDF, Paper, Fabric, Textile, Leather, Marble, Ceramic etc.
5)10W--50W Fiber laser ( LF series)
Engraving and Marking any Metal and some non metal (ABS
plastic)
6)100W,150W, 275W CO2 Galvo Laser Marking Machine (LRs eries )
Marking wood, leather, Jeans, Garments, Fabric, Acrylic (light guide plate)
ok,if nay enquiry of fiber cutitng machines, please conatct me :
skype:wkquiven
[email protected]
whatsApp:8615698041856
