585,676 active members*
4,049 visitors online*
Results 1 to 10 of 10
    Dec 2005
    258
    Solid State Relay (SSR) Question
    The ssr works and kicks on no problem IF i use a 6v battery pack to juice it.
    If i use the BOB it doesnt. I have everything setup correct and mach3 is controlling the Pinoutput fine.
    The problem i have is before i attach the ssr i get 4.99v across the gnd and output pin from the BOB. Once attached to the SSR it drops to 2.8v
    I add 5v 1.2a power supply to my BOB but it doesnt help.
    When the battery is plugged in and i check, the voltage is the same as when the battery is unplugged.
    I get the idea that voltage drop could be due to lack of mA but a 1.2amp supply should be enough. What am i not getting or understanding?
    TIA!
    Eric
    24220
    Re: Solid State Relay (SSR) Question
    What is the part number of the SSR?
    What is the input range?
    Is it DC or AC output switching?
    What BOB?
    Sounds like the output from your BOB is not compatible.
    Al.
    Albert E.
    Dec 2005
    258
    15362
    Do you have the 5v/common on both connected inputs, you need it on both lots of optos the computer side and the output side, your breakout board is showing where to connect the input power
    Mactec54
    Dec 2005
    258
    I have (-4) on GND pin next to P17 and (+3) on P14
    I have 5v 1.2a psu connected at the top right 5v and GND on the right. But it doesnt seem to help.
    Someone mentioned wiring (+3) to the 5v psu and the (-4) to P14 because it can prob pull down better than supply 5v.
    Sent from my LG-LS997 using Tapatalk
    Mar 2007
    2083
    Hi Eric
    I have found what looks like a version of your BOB and working from the photo
    it looks like the 12 outputs have a 1k pullup resistor connected to +5V
    and are also connected to the Collector of the NPN transistor thats part of one of the twelve PC817 opto isolators
    the Emitter is connected to the BOB's GND
    So you need to connect the SSR treminal 3 (+) to the BOBs +5V
    and the SSR terminal 4 (-) to one of the BOB's outputs
    Attachment 351030
    the SSR switches ON when the output goes low
    John
    Dec 2005
    258
    John,
    I got your reply too late. I already hooked it up but without the pullup resistor. Seems to work fine so far.
    Thx for your time!
    Jun 2010
    4256
    I would be a little cautious about running it with no pull-up resistor. You would be relying on the current limit in the output driver, and that may cause it to overheat. I suggest you try a few different small series resistors, or just calculate from the SSR specs what the resistor should be.
    Cheers
    Roger
    Mar 2007
    2083
    Hi
    the twelve pullup resistors are on the breakout board , the long yellow arrow points to the resistor on the board and the circuit running along the PCB edge is part of one output
    John
    24220
    It has been my experience that the current required for most SSR's is not that high, it would be easy to find out by supplying the 6v as in the OP and measure the current.
    Al.
    Albert E.
  1. Solid State Relay Question (Hopefully Easy)
    By Shoulder_Devil in forum DIY CNC Router Table Machines
    Last Post: 04-18-2011, 02:44 AM
  2. 24Vdc Solid State Relay not the same as mechanical relay??
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 11-10-2010, 07:40 AM
  3. Using a solid state relay as a main stop relay
    By garagefela in forum CNC Machine Related Electronics
    Last Post: 02-26-2010, 11:27 PM
  4. solid state relay question
    By aegfurn in forum CNC Machine Related Electronics
    Last Post: 02-24-2007, 04:09 AM
  5. Solid state relay
    By N4NV in forum CNC Machine Related Electronics
    Last Post: 05-07-2006, 06:19 AM
