585,994 active members*
4,600 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Shopsabre > Touch pad for setting z-zero on a 4896ATC?
    Dec 2007
    All:
    I recently acquired a used 4896 with ATC and have finally set it up for use. I love the tool measure option, but I feel like zeroing the z-height is still a little fiddly as it depends on my setting the bit at the right height manually. My machine did not come with the touch pad and I was thinking of getting one. What do folks do for accurate z height set up?
    Anil
    Jan 2010
    77
    Re: Touch pad for setting z-zero on a 4896ATC?
    I bought mine direct from wincnc which is the operating system guys. If you need help and support, you may be better off getting one from shopsabre. I wouldn't go without it.
    Dec 2007
    Quote Originally Posted by kenrbass View Post
    Thanks I do have an email out to SS regarding this. Kind of pricey, but I guess for the convenience it provides (and hopefully the accuracy), it's probably worth it.
    Anil
  1. Setting up Tormach Touch Screen
    By GTOGuy in forum Tormach Personal CNC Mill
    Last Post: 01-20-2017, 09:17 PM
  2. 4th axis post processor and set-up on 4896ATC
    By Hypotenuse in forum Shopsabre
    Last Post: 01-16-2017, 04:47 AM
  3. touch probe/Z0 setting block advice
    By dougie329 in forum Controller & Computer Solutions
    Last Post: 11-18-2009, 10:44 PM
  4. tool touch off and offset setting
    By Runner4404spd in forum Fadal
    Last Post: 02-16-2009, 01:48 PM
