585,931 active members*
5,311 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Cam works 4 axis mill
    Jul 2013
    84
    Hi Forum,
    I have SW/CW and working my way through each project - thus learning more, however i am stuck on this - at least how i should approach;
    Scenario - Sherline mill (with indexed as 4 axis)- mach3 and CW for SW
    Question:
    The process of mill setup for for 3 axis seems pretty straight forward as there is only the XYZ. in the case of a 4 axis (indexer as above) hgwo is this approached in CW/SW as most of what I see is the z Axis moves rather than the material ( or am i looking at this the wrong way?). In part I assume the movement will be translated to a indexer rotation?, but is this really how i should approach this
    bit lost here and looking for an overview approach to begin
    Jan 2014
    16
    Re: Cam works 4 axis mill
    In Camworks options your can choose to rotate stock.
    Select a 4 axis machine or create one in the database with your machine specifications.
  1. How the Rotary axis works
    By AmyThunderlaser in forum Thunder Laser
    Last Post: 05-03-2017, 08:54 PM
  2. Problem with VSD-E in DualDC drive mode, axis 1 works but not axis 2.. any ideas?
    By bmquist in forum CNC Machine Related Electronics
    Last Post: 08-31-2014, 04:08 PM
  3. Big Dog Metal Works BF-25 mill
    By tmarks11 in forum Benchtop Machines
    Last Post: 06-08-2011, 05:04 PM
  4. X axis works fine but Y axis direction is erratic
    By swampbud1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2010, 12:28 AM
  5. Upgraded to 4.0, now only X axis works??
    By Mueller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-04-2005, 04:23 PM
