584,812 active members*
5,331 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Alarm 39-83 spindle drive fault
Results 1 to 14 of 14
    Jun 2015
    56
    Hello all,
    I have a 39-83 alarm on a Arrow 1000 with an A2100 control. This machine had the VFS5 rebuilt 7 months ago and has been ok till now. I had this alarm a few times over the last month , it would trip when the machine was idle , like during a setup. This morning though it wont run at all though. I dont get a fault on the drive itself at any point. I dont have motion control software yet to pull the actual drive data, I am working on that now. In the meantime , if you guys have any wisdom to share , It would be awesome.
    Jun 2015
    56
    Re: Alarm 39-83 spindle drive fault
    Update : I unplugged the C1 plug (fan) on the psr4 and replugged it and now the machine fired up fine. ( I did the same on the VFS5 but it didnt help, couple hours later I tried this) Hopefully it is just a loose connection ??
    Sep 2010
    1765
    but a2100 says spindle drive reports a fault.... yet y ou say the red fault lite on vfs5 is not on?? how can this be?
    hmmm... the fans are just 120v IIRC fans... psr4/5 has its own fault output, and fan not running is not one of its reasons to say fault... weird...
    vfs5 DOES watch heatsink temp inside: Cincinnati actually brought the thermostat OUT and back in the top ribbon cable so they could report overehat conditinion... you dont report that? prob not the issue then...
    fault on 2100 says spindle yet no red lite. how do we geta round this?
    Jun 2015
    56
    Quote Originally Posted by Muggins View Post
    Update again,
    I got the alarm back again less than five min after getting it running. I ran the spindle for a bit then stopped the spindle and started a setup. Alarm came when spindle was stopped for a few min.
    Thanks for the help
    Sep 2010
    1765
    Update again,
    Thanks for the help
    still makes no sense.
    time to look at wiring diag. got one, right? got someone who can read it? find CRx....
    21000 says m1spdl... input missing
    vfs5 says bull**** it is on (no red lite)
    relay in between defective? broken wire?
    Jun 2015
    56
    Quote Originally Posted by mike_Kilroy View Post
    It wouldn't be the regen if I get the alarm when not running the spindle right?
    Sep 2010
    1765
    Should not be. Fault say spindle ready missing: ie,spindle red lite on.
    Sent from my SM-G900V using Tapatalk
    Mar 2011
    460
    I don't think the fault actually said anything about spindle ready missing, and I believe that is a different input.
    Like Mike said, look at your prints. Follow the input back to figure out possible causes. IIRC, Cincinnati had 2 relays in series to that input, either of them, the wires, or the connections could be causing the issue.
    Sep 2010
    1765
    Quote Originally Posted by maver1ck View Post
    Thanks for the clarification. cincinnati mostlyl calls our fault output relays "drive ready" feedback, so I ASSumed this was the same fault output. I had hoped they would LOOK AT THEIR PRINTS but in all this time it has not happened. If I get a free moment today I will breakdown and read it for them and point to the possible culprits.
    Sep 2010
    1765
    When I get time I will look at arrow print for you; not sure why the fault screen would mention regen as possible issue since last time I looked our fault contact on the PSR unit is in series with our VFS5 watchdog relay and theese two are in series with the green go button that fires M20 main contactor for PSR.
    Sep 2010
    1765
    maver1ck, I sent an email to what I believed was your email address a week ago. I receved no reply, did you get it?
    Do you go to customer sites to help people? Maybe close to you? If so, I would like to know as we get requests for possible tech help visits up your way occasionally.
    Sep 2010
    1765
    OK Muggins, I looked at your print for you. You really need to find someone local who can read your prints; they give you a clear path to fixing your issue quickly.
    I attached two pix of your prints showing the areas your alarm says has an issue. Can you read these?
    As Maver1ck said, there are TWO relays, CR25 & CR26, that make the missing fault signal - I attached print of how they are wired. You should have a tech capable of reading wire numbers and checking that those relays are turned on properly. We bring the internal VFS5 heatsink thermal switch OUT thru the top ribbon connector of the drive and back in and input so the a2100 can watch it instead of us inside the drive like normal. This turns on CR25. Then too the motor has a thermal switch. This turns on CR26. THE SERIES STRING OF THESE IS NOT GETTING TO THE A2100.
    I do not see why they mention the regen at all: it has a thermal overload relay in series with the DB resistor. This turns on CR24 and is a ready sig not fault sig - see pix I attached.
    Not sure how else to help you find the open circuit other than recommending a voltmeter and testing these wires.
    Oct 2016
    106
    Hi.
    I have similar problem.
    I bought another vfs5 275 00120 26044.
    It doesn't give signal to cr25 and cr26.
    Stripped it down, overtemp sensor is fine, 0ohm, inside vfs5, but the 24v doesn't get to cr2 cr25 cr26 cr27
    Are there any diagrams for vfs5 available?
    Sent from my D5803 using Tapatalk
    Sep 2010
    1765
    Fives sells the wiring diagrams of those machines:
    (800) 934-0735 IIRC
    fivesgroup.com
    email sent with a couple ideas...
  1. Alarm # 123 Spindle Drive Fault
    By Web.eng in forum Haas Mills
    Last Post: 02-05-2020, 07:33 PM
  2. Alarm 123 DRIVE FAULT on startup.
    By DZANDF in forum Haas Mills
    Last Post: 04-14-2014, 01:25 AM
  3. Replies: 6
    Last Post: 01-06-2014, 05:01 PM
  4. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  5. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
