585,948 active members*
3,744 visitors online*
Results 1 to 15 of 15
    Feb 2017
    11
    Best bullnose/ball bit for the job
    I have been lurking for some time and decided to finally post a question. I am making some instrument fingerboards in fusion360. I have all thetoolpaths correct but i am struggling with the final pass. They come out real rough looking and need a whole lot of extra hand work to clean them up. My question is what bit should i use to clean them up to on my final pass? Are there specific brands/sizes you guys might have good luck using? Any advice is greatly appreciated
    Dec 2013
    5717
    Re: Best bullnose/ball bit for the job
    The finish may be more of a function of technique, feeds and speeds, rather than the endmill, a bullnose might be helpful, or not. What material? Width of cut? Depth of cut? Direction of cut, climb or conventional? Any cutting fluid?
    Some pictures would be helpful
    Feb 2017
    11
    Jim,
    I'm using a 1/2" ball bit. The feed is 92 in/min. Speed is 1000 ft/min . For the material, I used MDF for my first test and ebony for a second test. I was able to hand scrape the ebony clean so it was not a loss. I am doing a tiny step over of .05" thinking it might clean it up better. I will post pix tomorrow when I'm back in the shop. I would be glad to share my fusion model with you if need.
    Thanks again
    Dec 2013
    5717
    Sure, I would be happy to look at you Fusion model. Understanding the shape of the part would be a big help.
    Jun 2010
    4256
    The odds of getting anything useful from MDF are close to zero, imho.
    Try cheap hardwood if you can find some. Second hand building materials are a good source.
    ?? Speed is 1,000 RPM maybe? That's very slow.
    Cheers
    Roger
    Feb 2017
    11
    So here is the file. I probably have the numbers wrong. I need to preface that this is my first 3d model that i have tried to cnc. I do cabinet parts with it and thats it. Maybe its my fault for trying something new.
    Thanks guys
    Dec 2013
    5717
    I looked at the file, I need to think about it for a bit to come up with a plan.
    Feb 2017
    11
    .05" is not a tiny stepover. Try .01-.02" for your stepover.
    Dec 2013
    5717
    After running some simulations, I agree with Gerry, you need less stepover. You can speed the process up a bit by swapping the X and Y axis and that might improve the finish or at least make it easier to final hand finish because the striations would be in the long axis
    I didn't look at the file, but I'd definitely be running along the fretboard, with the grain.
    Feb 2017
    11
    Thanks guys. Ill look at doing that. What bit do you guys recommend? The same 2 flute corebox bit or is there something else that might work better?
    Dec 2013
    5717
    The corebox bit should work fine if it's nice and sharp. You may have to experiment with feeds and speeds to get the finish you want.
    Feb 2017
    11
    I performed some tests today. The thing that made the biggest diference was the stepover. Thanks to all that helped
    May 2006
    803
    I find this place really tuff to compete with.
    Seriously think of your time and effort.
    They vary in thickness but top and slots are perfect
    Buy vs D.I.Y.
    Allen Guitars & Luthier Supplies
    Been doing this too long
  1. SOURCE FOR TAPERED BULLNOSE END MILLS?
    By Tolyatti in forum Moldmaking
    Last Post: 07-30-2015, 03:21 PM
  2. Bullnose posting.
    By Karlwknc in forum Cincinnati CNC
    Last Post: 08-12-2010, 10:31 PM
  3. 6cm Full Bullnose
    By DennisCNC in forum Glass, Plastic and Stone
    Last Post: 09-06-2007, 03:10 AM
