585,591 active members*
2,467 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Molding/Plug Tutorials/Videos
    Feb 2004
    95
    I'm looking to make a plug of an model airplane fuselage and make a mold of it. Are there any tutorials or videos on this subject. I've seen a few on making a helicopter canopy that were really good but I'd like to see something on a aircraft fuselage.
    1213
    If you try searching for information about the principles of producing patterns for metal castings you will acquire most of the information you need. The difference begins when you reach the stage of applying a good finish and then a release agent.
    As you are posting on a CNC forum, are you planning to machine your proposed shape?
    Sep 2003
    1113
    barkster -
    here are a few sites you might take a look at. I assume you are talking of molding in fiberglass/carbon and resin? You could build the mold (a 2 piece female mold) on the cnc then layup the two fuselage halves in the mold and when cured, release and join them together like the old plastic model days. I'd use delrin/acetal as the mold material and a bit of pva release wax.
    Else the sites have some good ideas too:
    https://www.cstsales.com/How_to_Articles/fiberg0.htm
    http://www.rcglider.com/GOV.htm
    http://www.inlandsloperebels.com/tips/tips.htm
    http://www.favonius.com/soaring/lost_foam/lost_foam.htm
    The lost foam approach is kina cool. You could make the foam fuse then do the procedure. OOps another secret outa the bag! Gues I won't be selling any of those now.....
    :cheers: Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Feb 2004
    95
    Thanks Jim sometimes I forget to mention what I'm really trying to do but you nailed it on the head. Thanks for the links
