585,715 active members*
3,961 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Large Cast Part, Rigid Mould Advice
Results 1 to 5 of 5
    Dec 2013
    7
    Hello all,
    I need some advice for a small run of parts I need to cast.
    The part is essentially a hollow hemisphere with a flange and o-ring groove and a filling port.
    For scale the sphere diameter is 170mm (~7") and the wall thickness is 5mm (~1/4").
    I need to make around 10 of these parts and a key factor is that they are as dimensionally accurate as possible. They need to be rigid and transparent, so I'm thinking of using a resin.
    Attachment 352816Attachment 352818
    My concern is how best to produce the moulds for casting. I think it needs to be a two part design, but if I use silicone I worry that the large mass and cavities of the moulds would not remain dimensionally accurate.
    (This is just a concept section view to illustrate the point, I haven't designed the mould yet)
    Attachment 352820
    Does the mould need to be flexible? Could I just get the two mould halves CNC machined / 3D printed from a rigid material, or would removing a rigid cast from a rigid mould be too difficult?
    Apr 2004
    5734
    Re: Large Cast Part, Rigid Mould Advice
    Assuming that all the holes and edges in the model are drafted sufficiently, then a rigid mold should work. A fiberglass-reinforced polyester or epoxy layup would be lighter, cheaper, and more dimensionally stable than the silicone block you've drawn. A 3D printed mold would not be as strong, since they tend to come apart at the lamination lines. Use several layers of a good mold release and you should be fine.
    Andrew Werby
    Website
    Dec 2013
    7
    OK, I'm new to this. When you say polyester or epoxy layup, would that involve creating a master pattern and then forming the moulds over that by hand, including features like keys for alignment?
    Cost isn't a major issue, but I need to ensure very high quality parts and as this is my first time casting I'd like to simplify the process somewhat.
    I would need to get the master part machined anyway, could I instead design the two moulds and get them machined? They are around 100mm deep so not sure what material choices I would have. Would something like Renshape offer a quality surface finish for transparent resin, and hold up to 10+ castings? Overkill I know but how about solid aluminium moulds?
    Apr 2004
    5734
    Quote Originally Posted by bradlar90 View Post
    [Right.]
    [The master part could either be machined or printed. I suppose you could machine the molds from big blocks of plastic instead of laying them up, but the amount of material and the cost would be a lot higher, while the strength would be lower.]
    [Renshape would be acceptable as a material for the model, but not for the molds.]
    [They would probably work, but be sitting down when you read the quotes for that...]
    Andrew Werby
    Website
    Feb 2006
    196
    I agree with Andrew. A CNC machined Renhape or Aluminum mold would work fine but cost may be an issue.
    If you take the time and expense to machine a master pattern you might as well machine a mold.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
  1. Quote needed for cast aluminum part
    By Shanghyd in forum North America RFQ's
    Last Post: 11-20-2015, 11:20 PM
  2. Newb looking for advice on diy cnc mill thats rigid
    By joedesu1 in forum Open Source CNC Machine Designs
    Last Post: 10-05-2010, 09:51 PM
  3. How large air compressor to use for cast acrylic?
    By Metalmidget in forum Tormach Personal CNC Mill
    Last Post: 09-06-2010, 08:04 PM
  4. Silicon Rubber compression mould advice ??
    By kevh in forum Moldmaking
    Last Post: 05-29-2009, 05:33 AM
  5. need more advice on rigid tapping
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 12-07-2006, 12:11 PM
