585,687 active members*
4,500 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > Laser engraving or Sandblasting glass and crystal which does the best job??
    Jun 2009
    77
    I guess sandblasting can carve deep if wanted and laser can not do this????
    Apr 2004
    5734
    Re: Laser engraving or Sandblasting glass and crystal which does the best job??
    Yes, it will cut a lot deeper. Sandblasting (actually done with silicon carbide grit, not sand) is also a lot quicker if you're trying to cover large areas. You can probably use the laser to cut your stencils, and then let the blaster do the grunt-work.
    Andrew Werby
    Website
    Jun 2009
    77
    Quote Originally Posted by awerby View Post
    I have a vinyl cutter I could use for some stencils if not to detailed. I see they can use a mask on material like Rayzist does and print with inkjet and then expose
    to UV light in their expose unit. I like the idea you can carve deeper if you want for a effect.
    I guess some of the large lazer machines can carve deep into wood but they cost alot Im sure but I don't think in glass even the big machines.
  1. Laser engraving crystal
    By thunderlaser in forum Videos
    Last Post: 05-09-2013, 06:24 PM
  2. Laser engraving crystal
    By thunderlaser in forum Thunder Laser
    Last Post: 03-15-2013, 09:15 AM
  3. Have you heard of Shining3D Crystal Laser Engraving Machine
    By shining3d in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-08-2011, 08:57 AM
  4. Supply mini 2D/3D crystal laser subsurface engraving machine
    By 3dlasermachine in forum News Announcements
    Last Post: 09-08-2009, 04:15 AM
