584,802 active members*
4,833 visitors online*
Results 1 to 16 of 16
    Mar 2016
    46
    retrofit Z axis, shoptask
    Hey JT, I recently retrofitted the Z axis on my 1990 Shoptask mill. I Completely eliminated the worm gear and the rack and pinion which was part of the original design. the new configuration works very well. I am attaching a few photos, thought there may be a few individuals who may be interested. One question I would like to know is the approximate weight of the machine with out a stand. Thanks a lot. Hope the pics are attached
    Dec 2013
    5717
    Re: retrofit Z axis, shoptask
    Would love to see your work, but no pictures
    Mar 2016
    46
    ya, I would like for you to see them, I did put pics on before, thought I did today too, I converted them to jpeg and and opened them but apparently nothing happened Can I still attach to the old post or thread, thanks for the help.
    Dec 2013
    5717
    Quote Originally Posted by CAD226B View Post
    If the Edit Post is still available to you, then you should be able to add pics.
    Mar 2016
    46
    ok ,thanks, I will try to get the photos on sap, maybe not tonight though, thanks
    Dec 2007
    77
    Nice work- I see you also modified the lathe spindle to a thread-on chuck. 27 years old and still working!
    Dec 2013
    5717
    Looks good! I like the E-stop on the back of the computer
    Mar 2016
    46
    Thanks all, the last question was satisfied. The new ones are (1) since I did change the I and J to Incremental it seems that the screen display shows a circle as an oval (long the X axis) how to remedy this? (2) and also when I home the machine and move to center of X and Y axis more or less and I load a g-code that is not out of limits , the display shows that it is by stating aborted ...etc, I did get the bottle of Jim Beam but I haven't opened it yet, thanks for all the help!
    Sep 2005
    127
    CAD226B, I've got a Bridgemill and I'd like to put ballscrews on my Z (actually all 3 axis). Any chance you have drawings of what you did that you would be willing to share?
    Mar 2016
    46
    dgapilot, Though I did respond the same day you posted, I will try it again, I never had real working drawings for the retro fit, only a bunch of PAINT sketches that only I could probably use. On the Shoptask I started with the existing mounting plate and attached a vertical .5" x was it 4" wide CRS with a sliding 3" piece of cold rolled steel for the end mount for ball screw pillow block made of .5" aluminum stock. this is attached to the horizontal bracket which was bored to the size of the existing Shoptask spindle. The only other help I could provide is more photos. good luck !
    Sep 2017
    14
    Nice job ... looks more rugged then the kit they offered years ago to make the Z ballscrew
    Mar 2016
    46
    Quote Originally Posted by dgapilot View Post
    Hey dgapilot, I just ran across some of the old drawings for retro fit Z axis that may be of some use to you if you are still interested. If you are, please let me know and I will forward them to you.. I am not sure how to do it but I think the best way would be to send then in email. or ? Have a good one. About 5 or 6 sheets.
    Sep 2005
    8
    I'd certainly be interested in seeing those prints, looking at an update on my xtmc!!! Thanks!
    Mar 2016
    46
    ok techsol, I would have to say that generally these drawings which were done before the stabilizer bar was built are really just sketches on paint that may be helpful to you. Although they are drawn to scale there is by no means enough detail for a machine shop to be able to produce them and fit them to a shop task machine or other similar milling machines. If you are still interested please let me know and I'll get to sketches to you soon as possible. And the best method of doing so. Thanks TG
    Sep 2005
    8
    Hi Cadd226b, would certainly like to see if not a big deal, extra thoughts and detail always help. Thanks!
    Mar 2016
    46
    Good morning techsol, there are 10 sketches I really don't want to attach them to this site. It would be much easier to send them by email to you, only if that is acceptable by CNC zone. So I will give you my email address which is [email protected] and we can go from there, thanks.
  1. Replies: 2
    Last Post: 06-26-2023, 04:26 AM
  2. 4th Axis Retrofit VMC 760
    By jimmyjolly in forum Bridgeport / Hardinge Mills
    Last Post: 08-28-2016, 09:57 AM
  3. Power feed for 1720 shoptask y axis.
    By dogboy in forum Want To Buy...Need help!
    Last Post: 01-27-2013, 03:21 PM
  4. O.T. 4 axis CNC Shoptask 4 sale
    By ozzie34231 in forum Shopmaster/Shoptask
    Last Post: 07-23-2012, 03:27 PM
  5. BP S1 Z axis retrofit
    By CNC OT in forum Bridgeport / Hardinge Mills
    Last Post: 09-05-2007, 09:42 PM
