585,753 active members*
3,826 visitors online*
Results 1 to 6 of 6
    Jan 2014
    28
    HiCON Integra vital systems
    any one use the HiCON Integra from vital systems I building a plasma and think this is a good controller
    also want to use the proma thc thay have a new one using no relays
    any input on this
    Re: HiCON Integra vital systems
    It's supposed to be one of the best Mach3/Mach4 motion controllers, but I don't know anyone that's used one.
    Jan 2016
    33
    I use the hicon integra. Ive had it for about 6 months.
    Im very happy with it. They also have alot of addons for purchase when you need them later.
    I just purchased the closed loop activation and have been playing around with it.
    Feb 2014
    35
    I know this is late, sorry...
    Yes, I have the HiCON Integra - 6-Axis Step/Direction Ethernet Motion Controller (pn 7766). I've been running it for about two years without any problem. Hook it up correctly and it, just works.
    Since I moved from the hobby controllers' to a more professional controller and servos, unexplained axis moves, control haults' where the bob fails to operate have completely evaporated.
    Mach3/4 is a popular cnc controlling software. There is a page at ArtSoft setup for Hicon. The guys from Vital Systems respond to queries quickly there.
    https://www.machsupport.com/forum/in...oard,89.0.html
    I like the hardware and the support. Hope this helps.
    BillT
    May 2016
    4
    hi can some one post screen shots of mach4 and HICON Integra i buy that board a year ago and i can't make it works with my mach4 i don't understand the HICON manual if any one have that working
    my software works and the Integra is recognized by the computer but i don't have any idea on the inputs and outputs to be able to use the board
    the motors don't receive any orders everything is wire but I'm lost with the manual thanks
    Feb 2014
    35
    I had a similar problem in the beginning...
    The Hicon Integra board needs two power supplies to operate. It needs a 24VDC power supply, as well as a 5VDC power supply. Without a proper power supply you will get nothing from it.
  1. HICON INTEGRA OHMIC ?
    By lkigam in forum CNC Machine Related Electronics
    Last Post: 12-31-2016, 09:32 PM
  2. Replies: 0
    Last Post: 03-14-2016, 10:33 PM
  3. HiCON CPU ethernet board for Mach3
    By Mike4703 in forum Controller Cards
    Last Post: 06-20-2012, 03:21 AM
  4. HiCon CPU board
    By Mike4703 in forum Machines running Mach Software
    Last Post: 05-13-2012, 09:40 PM
  5. Why is a heavy iron base vital for a good machine?
    By Com in forum Mechanical Calculations/Engineering Design
    Last Post: 11-29-2005, 04:41 PM
