585,758 active members*
4,106 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > L9101 and Z axis probing
    I'm trying to write code that will use double touch probing via L9101 to set a fixture Z axis offset. I'm trying:
    L9101 R1+1. Z-10. F50. P1
    What I am finding is that this gives me an error pertaining to axes. (I am not near the machine and don't have the exact error text.)
    Of note, I'm running this in G17 mode when it fails. I find I can run this in G18 or G19 mode and it lowers the probe, however it is simultaneously making an X and/or Y move.
    Any thoughts?
    Ryan
    Aug 2009
    12
    hi Ryan
    have u done? today i started on same project
    Tom
  1. Z Axis inaccuracy with Big-Tex Probing?
    By willower in forum Mach Wizards, Macros, & Addons
    Last Post: 02-18-2015, 11:03 AM
  2. Probing B axis with VM-3
    By machine_easy2 in forum Haas Mills
    Last Post: 04-15-2012, 12:31 AM
  3. 5 axis probing. Can Mach3 do it?
    By neilw20 in forum Machines running Mach Software
    Last Post: 02-10-2012, 05:40 PM
  4. 5 Axis probing on 88hs -4 system
    By carbidecraters in forum Fadal
    Last Post: 04-02-2009, 05:20 PM
  5. setting up 4th axis for DIY probing in Mach?
    By Rich05 in forum Digitizing and Laser Digitizing
    Last Post: 01-16-2009, 03:43 PM
