Is there a preferred bit to cut MDF.............I wan't to cut out numbers, shapes etc.
Also, is there a good sealer to seal MDF prior to spray painting? It just sucks spray paint in. I'm thinking of a dip ................any ideas? thanks
If you're talking about the top edge being rough, you can use a downcut spiral. Unfortunately, downcut spirals tend to get dull rather quickly. MDF in general tends to dull tools quickly. For best results, always use very sharp tools.
I have used spray-bomb enamels - those left a horrid finish on MDF - and oil based brush-on enamels - OK, still sucked the paint pretty good. If I ever paint MDF again I would be inclined to try spraying with an epoxy primer initially.
Oh, for some project I tried to seal MDF using polyurethane. That was REALLY sucked up. Sealed up really well but the finish was rough.
Hope this helped.
Seal the edges and the cuts with a mixture of 4 parts water and 1 part white or yellow glue.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
I find shellac based sanding sealer good.It may need to be thinned but one good coat,left to soak in and then when thoroughly dry,de-nibbed with 150 Fre-cut paper works well.
Take a few minutes and look this site over. This type finish is the best there is for mdf.
Mike
http://www.seagravecoatings.com/polyeste.htm
No greater love can a man have than this, that he give his life for a friend.
But I bet that would be some nasty stuff to apply in the garage.
Prolly! But I use a home made booth of sorts and it, or rather a product similar to it isn't too bad.
Mike
The best results I've had are with high solids 2-pack auto primer. Unfortunately, it uses an isocyanate based hardener, which is very nasty stuff.
I'm still hunting for a product that will really coat edges of MDF (so that they can be finished glass smooth) that isn't going to kill me...
Try finish sanding the edges, then brush on epoxy, and use an automotive spot putty to fill in any voids.
That might do it. Whilst I prefer spraying from the speed point of view, it's not real healthy without the right gear.
I know someone who's using epoxy paints, so I might be able to get a 'sample' for testing.
Do epoxy paints give off any dangerous fumes when painting with a brush?
Not paint, just regular epoxy, preferably a thin type. Use it as a sealer, then prime and paint.
Ah OK.
The only epoxy I usually see is in very small tubes in hardware stores (and is very expensive). I am aware you can get larger cans/drums of it, but it's not something I've ever noticed for sale. I'll have a hunt around.
No easy way to get a mirror finish to mdf. Hard work will prevail, lots of
sanding and filling. I use a waterbased filler, similar stuff to what you might
use when grain filling for polish.
JerryFlyGuy
The more I know... the more I realize I don't
Many thanks Jerry, I'm following that up right now!
Ive found the best way to get a really smooth finish on the edges of mdf is to sand it really smooth to begin with and then seal it with a water/woodglue mix as ger suggested. then a denib sanding will leave a smooth edge. paint with a sandable primer, and you can wetsand the edges super smooth.
I have tried water/glue, but found the sides of the MDF showed through after painting (it takes a few weeks).
Also, anything water based does tend to make the MDF move a little.
Once I can get hold of some epoxy, I intend to try various combinations of it, 2 pack primer, and an MDF primer I've picked up. It could be a while, but I do plan to post the results when I'm done.
Dear sploo,
I'm sorry you had no luck with water/glue.
Here is a link which gives a lot of information from lots of people about how to prime MDF. As you will see, opinions vary!
http://www.woodweb.com/knowledge_bas...nel_Doors.html
One more thing. I personally have never had any luck at all using water based primer on mdf.
Best wishes
Martin
