585,974 active members*
4,456 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > mb66vb osp300 : faster tools measuring and program assignment
    Jun 2015
    4154
    hello this is a procedure to setup new tools, by avoiding tool register
    general setup :
    ... assign a tool to each pot, thus tool library should be full in virtual setup
    ... if there is a behaviour to leave the spindle empty over night, than leave a pot empty
    ... this virtual setup will remain like this for a long time, unless a heavy tool drops in or something
    particular setup :
    ... put the tools inside the ATC and make a list with "tool type - pot"
    ... run the following program that will measure tools from specified pots
    ... there should be a list from the programmer, about "tool type - tool number inside the program"
    ... use a custom aplication, that will edit you program, so "tool number inside the program" to be replaced with " tool number on the cnc "
    thus :
    ... load tools inside the magazine
    ... input pot numbers inside a program and run it, so to measure all tools
    ... run an aplication that edits the program, by assigning to each opeartion the "real tool number", from the machine
    there is no faster way
    this program will measure tools from pots 6, 5, 7 and 14, thus edit only VC2 values ...
    will output a list with "real tool number" for each pot
    program prestages tools : while one is measured, next one is being prepared
    * VC1 is an increment so to handle cases when a single tool is measured, thus there is no prestaging for next tool
    * always finish with "CALL OTMP VC2 = 0", so to tell the machine that there is no next tool after the last one
    * i have no idea yet for the soubroutines names, so i used TMP and TMP2, from temporary
    * program uses a tool change macro : http://www.cnczone.com/forums/okuma/316654-forum.html
    Code:
        VC1 = 1
        CALL OTMP VC2 = 6
        CALL OTMP VC2 = 5
        CALL OTMP VC2 = 7
        CALL OTMP VC2 = 14
        CALL OTMP VC2 =  0
        M02
    OTMP
      IF [ VC1 EQ 1 ] N1 ( 1st measurement )
                 GOTO N2
          N1 VC3 = VC2
             IF [ VC2 NE 0 ] NEND
                 NRPT M0 ( no tools to measure )
                      GOTO NRPT
          N2 CALL OREG
             IF [ VC2 EQ 0 ] N22
                        GOTO N21
              N21 CALL OCHG LV00 = VPTNO [ VC3 ] LV01 = VPTNO [ VC2 ]
                  CALL OO30
                  VC3 = VC2
                  GOTO NEND
              N22 CALL OCHG LV00 = VPTNO [ VC3 ] LV01 = 0
                  CALL OO30
                  GOTO NEND
          NEND VC1 = VC1 + 1
    RTS
    OREG
      CLOSE C
      FWRITC tmp.txt;A
      IF [ VC1 NE 2 ] NSKP1
        PUT '*'
        WRITE C
        PUT ' '
        WRITE C
      NSKP1
      PUT '    POT : '
      PUT VC3 , 2
      PUT '    TOOL : '
      PUT VPTNO [ VC3 ] , 2
      WRITE C
      PUT ' '
      WRITE C
      IF [ VC2 NE 0 ] NSKP2
        PUT '**'
        WRITE C
        PUT ' '
        WRITE C
      NSKP2 CLOSE C
    RTS
    this is the output list :
    Code:
        POT : 14    TOOL : 53
        POT : 15    TOOL : 30
        POT :  5    TOOL : 56
        POT :  7    TOOL : 29
        POT :  6    TOOL : 26
        POT :  5    TOOL : 30
        POT :  7    TOOL : 56
        POT : 14    TOOL : 27
    "pot-tool" list is bounded between " * " and " ** ", so to be sure that program runned completly, and also to identificate the tools that had been measured during last program run
    this list should be handled forward, by an aplication, that will edit tools inside the program, so to suit the cnc
    Jun 2015
    4154
    Re: mb66vb osp300 : faster tools measuring and program assignment
    unless from what i have seen so far ... and i can make it perform even faster
  1. Replies: 13
    Last Post: 08-01-2018, 06:10 PM
  2. Vintage measuring tools, What are they worth??
    By PHiRe in forum Calibration / Measurement
    Last Post: 06-17-2013, 09:20 PM
  3. What measuring tools do i need to redraw this in solidworks?
    By diyengineer in forum Mechanical Calculations/Engineering Design
    Last Post: 08-23-2010, 07:55 AM
  4. help finding some new measuring tools
    By Teyber12 in forum Uncategorised MetalWorking Machines
    Last Post: 01-20-2010, 07:19 PM
  5. Asimeto measuring tools?
    By Chuck Reamer in forum Calibration / Measurement
    Last Post: 02-15-2008, 03:26 PM
