585,969 active members*
4,380 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > cutting a bearing seat in 4340 tube
    May 2015
    17
    I need to cut a bearing seat into the end of a piece of 4130 tube. The tube is 1/2 inch with an 0.083 wall. So that's .5000 OD and .3440 ID. The seat needs to be 0.3745.
    I can drill and ream to .374, but I need to get that last .0005, without going over. I can't get any boring tool I have into that small a space. I would appreciate any suggestions you guys might have.
    Nov 2012
    68
    Re: cutting a bearing seat in 4340 tube
    Quote Originally Posted by jimlake View Post
    Get it to .374 then just use sand paper to bring it to .3745, be careful, use fine grit, watch your fingers. Check the size often while sanding.
    Good luck.
    May 2015
    17
    I found a .3745 ream on MSC. Thx.
    1943
    Adjustable reamer also would work.
  1. Steel pipes cutting round tube and squre tube , fiber cutitng is best ?
    By laserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-23-2017, 10:42 AM
  2. Car seat cover laser cutting machine introduction
    By Dekcelcnc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2016, 08:32 AM
  3. Bearing Seat
    By bmurph in forum Employment Opportunity
    Last Post: 03-23-2010, 10:04 PM
  4. Tube cutting; tin slots and tube ends
    By marineboy in forum Waterjet General Topics
    Last Post: 10-13-2009, 10:03 PM
