I am new to this CNC field. I recently purchased a 3040T-DQ CNC (USB CNC ROUTER ENGRAVER ENGRAVING CUTTER 3 AXIS 3040T-DQ BALL SCREW USB PORT | eBay) machine with controller. (on the way). I am planning to use this tool for a different application hence I need to control it with my application which is being developed with MS C#. This unit has a USB port but I am not sure if it like FTDI RS232 USB to serial) interface or pure USB. I have never used pure USB but much familiar with USB to serial interfaces. Any one knows what is this interface ? ( I want to make use of this controller as it is and not want to replace the controller with any arduino shields).
Could some one shed some light about this ? Any help ? I mentioned about the arduino control since it uses simple USB to serial interface. In my real application, my C# will send the gCode to CNC controller when I have the connection. So trying to understand its interface/port info.
This unit says it supports only USBCNC. Not yet sure where to find the application.
Thanks for the help in advance.
Thanks,
P.
