584,862 active members*
5,341 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Leadshine MX4660: How does a pair of digitial outputs work?
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Dec 2009
    137
    Re: Leadshine MX4660: How does a pair of digitial outputs work?
    John-100, this is very helpful. When asked about a "controller" earlier this was what I was talking about. The installation manual was rather lean in the details. Here is the link to how to control the laser using PMW.
    CNC Laser Build Log
    The PWM connects to Output #1 to the VFD to control spindle speed in some automagic way. The MX4660 outputs on Output #1 & #2 a 12vdc with a + and - lead and PWM can be assigned to either Output. I understand the laser TTL is a high of 5 VDC and a low at 0 VDC. Other research on the same site suggests using one of their "controller' to manage the laser. Hence my confusing surrounding a "controller".
    I looked up the arduino ULN2003 board on eBay. These are cheap. The one I am looking at that most closely matches your diagram is
    https://www.ebay.com/itm/DC-5V-Stepp...sAAOSwA3dYNkB-
    Is this what you had in mind? How would the laser intensity be controlled? Since the laser has a single TTL+ wire, would the TTL- just be attached to the case?
    Thank you very much for taking the time to research and help me. It is very appreciated.
    Dave
  2. #22
    Mar 2007
    2083
    what laser and power supply are you using
    a tube and HT power supply like this -
Name:	Laser power supply TTL control.jpg
    or LED laser & low voltage power supply with PWM control ?
    that is ULN2003 is the ready made board I looked at
    I will have to study the PIC PWM control
    John
  3. #23
    Dec 2009
    137
    Thank you john-100. The laser is the Endurance.com 8w laser. The power supply is a 12DCV 6A I ordered from eBay. It showed up today, but unfortunately, it was a 19DCV 3.3A power supply. So it went back and now waiting again for the proper one. I ordered the ULN2003 mentioned above. It will be here on Saturday. Gives me a couple of days to catch up on other projects. Thank you so much for your help.
    Dave
  4. #24
    Mar 2007
    2083
    I guess your laser will be something like this -
Name:	8w laser.jpg
    John
  5. #25
    Dec 2009
    137
    Hi John, Pretty much. I have been researching big time. Here is one site will question and answers are found Endurance lasers. We produce and sell powerful and efficient diode lasers (solid state). Useful attachment to any 3D printer or CNC machine. And I also found this site. Endurance lasers. We produce and sell powerful and efficient diode lasers (solid state). Useful attachment to any 3D printer or CNC machine. This site describes using a "controller" much like you described. I also found out the 5dcv for the TTL+ can also be 12dcv. The 12DCV 5A powers the fans and laser. The TTL+ can be connected to the PWM output and attach that to the TTL+ line for intensity control. It described has being the spindle. Hopefully, the power supply will be here soon and I can try it out. Thank you for your help and interest.
    Dave
  6. #26
    Mar 2007
    2083
    I have had a look at the web links
    taken from the 1st link
Name:	NANO Board.jpg
    it looks like the Arduino Nano PWM output goes to an interface to drive a single NPN transistor TTL interface
    or 3 paralleled NPN transistors to control a Laser with just the 2 power connections
    given the option I would use TTL output to control a 3 wire Laser
Name:	opto-isolator circuit from NANO Board.jpg
    I'm not sure how well it will work as I would not expect the 3 individual paralleled transistors to equally share the Laser current
    I would of expected each transistor to have a low value resistor in series with the emitter
    {Note - the darling transistors inside a ULN 200x or ULN280x are closely matched & can be paralleled as specified in the data sheet }
    also the 10K potentiometer wiring looks odd
    from the second link
    this circuit using a FET looks easier to construct
Name:	opto-isolator & FET.jpg
    John
  7. #27
    Sep 2016
    9
    Hi did you ever get the laswer to turn on and off with the MX4660; I'm in the same boat and info seems to be sparce
  8. #28
    Dec 2009
    137
    No. It is almost impossible to do without disabling, aka using the spindle PWM circuit. The MX 4660 doesn't support two independent PWM circuits. The TTL+ line, however, can be easily managed using the 3rd port on the ESS with the M7/M9 commands. Ultimately, the TTL+ circuit proved to be defective as it it would not turn off. +5vdc or 0vdc made no difference. If connected, it would turn on the laser. I returned the laser to Endurance and now trying to get my money refunded.
    The idea was to use the spindle and laser together. User laser to engrave some test or objects and the spindle to cut them out. Doing a major machine restructure on every project just wasn't acceptable.
    Dave
Page 2 of 2 12
  1. Motors don't run - Mach3- Leadshine MX4660 - UC100 USB
    By pilotarix in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2022, 06:46 AM
  2. Replies: 8
    Last Post: 04-13-2018, 08:48 PM
  3. Replies: 9
    Last Post: 08-30-2015, 01:23 AM
  4. Nema34 electronic for a 48x60 build with Leadshine MX4660 and KL34H260-60-4A
    By javabugz in forum DIY CNC Router Table Machines
    Last Post: 10-16-2014, 04:21 PM
