585,668 active members*
4,024 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Leadshine MX4660: How does a pair of digitial outputs work?
Page 1 of 2 12
Results 1 to 20 of 28
    Dec 2016
    4
    I am trying to control a small 12vdc relay via a digital output to control a SPDT logic switch. The relay's nominal power is 360 mW. I have tried wiring per manual with no success. To solve my problem, I need to understand what is going on between the + and - digital output terminals. When the pin is high or low, I don't measure any voltage across the leads, nor any continuity? Any helpful explanation or suggestions would be much appreciated!
    Mar 2008
    1762
    Re: Leadshine MX4660: How does a pair of digitial outputs work?
    Tom..
    Connect "+12vdc out" to "Output 1+"
    Connect Positive side of relay coil to "Output 1-"
    Connect Negative side of relay coil to "GND"
    If using >12vdc from another source, use appropriate current liming resistors.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Sep 2005
    1195
    Hello Gary,
    How about if the relay using 24 DC ? or 220 VAC ? How to wire ?
    Mar 2008
    1762
    Tom...
    The info is shown pretty clearly in the manual. Up to 24vdc with a resistor. 220vac, no, use the relay for that
    Dec 2016
    4
    Dec 2016
    4
    The image I posted shows the two configurations I've tried with no success. Using islaww's method, I measure 11.8v between GND and Output 1- and 10.9v between GND and Output 1+. No change in measurements with pin 17 hi or low.
    Using the configuration described on page 16, last paragraph of the manual, I measure 1.25v between Output 1+ and GND with no voltage change when Pin 17 hi or Lo.
    I have also tried using other Output terminal pairs with no success. Any more suggestions?
    Quote Originally Posted by Tomboardman View Post
    I'm having the exact same issue. Did you ever solve it?
    Dec 2016
    4
    No, I finally gave up. So, I continue to manually switch my spindle to run mode until I, some day, resolve the issue. Let me know if you ever find an answer!
    Mar 2008
    1762
    I do a bunch of these. The VFD will require a mechanical relay to trigger FWD rotation. I'm using a 24vdc relay and small power supply to do this. Wired as follows:
    24v+ to Output1+
    24v- to relay coil negative (A2)
    Output 1 - to relay coil positive (A1)
    Thanks for the reply islaww.
    That is how I believe I have it connected. I'm using the SainSmart 4 channel relay board. In1 (5v from relay) to Output+, Output- to ground.
    Here is my understanding of how it works: When the opto is on it should complete the circuit and activate the relay and when the opto is off it breaks the circuit and the relay is off.
    My issue is that the output appear to always be ON. The only way I can get the relay to be off is by disconnecting the DB25 connector from the leadshine.
    Note: I am using a Mesa 7i92M as my motion controller from Linuxcnc.
    Mar 2008
    1762
    Sorry...
    I am not familiar with those components, so I cant help there. The output + and- terminals are a simple ttl switch. They should switch 3-32vdc as long as the polarity is correct.
    Exclamation Re: Leadshine MX4660: How does a pair of digitial outputs work?
    I solved my issue last night. For me it was an issue with the actual output signal from the Mesa 7i92 controller, not the Leadshine.
    I was using only the following hal command assuming it would set that GPIO to an output:
    net signal-name => hm2_7i92.0.gpio.000.out
    I needed to add the follow so the GPIO is treated as an output. The default appears to be an input:
    setp hm2_7i92.0.gpio.000.is_output true
    My only remaining issue is the Mesa appears to initially start high (or true) so when I first power up the mesa and leadshine the relay will activate. Once I start Linuxcnc the mesa .is_output is read and the relay turns off. After that the relay control works as expected. I am using this relay for spindle control so if I power the spindle VFD before starting Linuxcnc the spindle would start spinning.
    Any ideas to fix this?
    Dec 2009
    137
    Quote Originally Posted by islaww View Post
    Sorry...
    "The output + and- terminals are a simple ttl switch". I am trying to connect a laser engraver to an existing CNC machine. It takes external 12vdc 6A to drive the fans and power the laser. The laser also has a single TTL+ input wire to control on/off. I have a 4 port relay (HL-54S) that I can use. I have an ESS with both ports connected to the MX4660. Output #5 is Port 2, Pin 17. The plan is to use Mist M7/M9 to control laser on/off. I'm not sure how to get 5vdc to the single TTL wire. Thoughts?
    Mar 2007
    2083
    having a quick look at the MX4660 manual the digital output is the NPN transistor in an opto-isolator in series with a 1K resistor
    Attachment 387486
    as the 1K resistor will limit the possible current when the digital output switches on
    the MX4660 will only be able to directly switch a small relay on & off
    if you connect a 5V relay that has a 200 ohm coil
    you will need to use a 28V to 30V supply
    1/6 of the supply will be across the 200 ohm coil and
    5/6 of the supply will be dropped across the 1K resistor inside the MX4660
    the easy solution is to use a relay with a transistor driver
    John
    Dec 2009
    137
    Thanks, John-100. I have studied these pictures for hours. I have already set up my spindle with RPM control, all the limit switches, and the auto zero. I am at lost on how to control the laser light using the M11/M10 commands using an MX4660. The 12vdc connection is simple. How do I connect and test the M11P3 command? I don't want to blow up the MX4660. The spindle on/off is using Output#1 + & -. The laser on/off uses a single wire TTL+ signal. So how can I connect it to the MX4660 and switch it on/off? Thanks for any ideas.
    Mar 2007
    2083
    which laser & power supply are you using ?
    if the laser has a TTL on off control
    may be a NPN transistor or N channel FET can be used to convert the MX4660 digital output
Name:	MX4660 digital output to TTL.jpg
    John
    Dec 2009
    137
    The laser is an 8 W from endurancelasers.com. The power supply will be independent and operate at 12vdc 5A or so. The laser has a TTL on-off control. Making that work with the MX4660 is the problem. It is increasingly oblivious I will need a independent laser control that takes in 12vdc and outputs a TTL signal. I am more software than hardware and eBay has a lot of junk. Can you recommend a laser controller solution I can simply buy that will work? Thanks.
    Sep 2005
    1195
    If you buy endurance, they will give you a laser controller ?
    Dec 2009
    137
    Maybe it's the definition of a controller. It has a 'controller'. If you feed it the 12vdc it will work. The laser comes on, the fans run, and the beam hits the wall. It also has a TTL input to control the laser beam on/off. With the PWM the intentisy can also be control. I just need some way to control the laser beam using Mach3->ESS -> MX4660. One solution would be to create another profile called 'laser' and change the spindle properties to control the laser. Then just switch profiles as needed. I was trying to avoid that. I have done so much research that I may be confusing terms. So, the laser has a 12vdc input for power and a TTL input for laser control. I guess it does have a controller.
    Mar 2007
    2083
    I have had a quick look at the arduino ULN2003 boards used to control stepper motors
    Attachment 387662
    this is how you can use one to connect the MX4660 digital output to your Laser
    using a ULN2003 board connected to a 5V supply that also powers the MX4660 digital output circuit
Name:	MX4660 digital output to TTL using ULN2003 board.jpg
    John
Page 1 of 2 12
  1. Motors don't run - Mach3- Leadshine MX4660 - UC100 USB
    By pilotarix in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2022, 06:46 AM
  2. Replies: 8
    Last Post: 04-13-2018, 08:48 PM
  3. Replies: 9
    Last Post: 08-30-2015, 01:23 AM
  4. Nema34 electronic for a 48x60 build with Leadshine MX4660 and KL34H260-60-4A
    By javabugz in forum DIY CNC Router Table Machines
    Last Post: 10-16-2014, 04:21 PM
