Most of the scales available are TTL, with the exception of some Heidenhain, which can be either TTL or low signal sine wave.
You should only require a marker at one end for zero index.
You may have a problem with 'hunting' if you have any degree of backlash between motor and scale, unless you go with dual feedback, motor encoder AND scale, but I don't recall if the 6 will support D.F.B.
Also I seem to recall the scaling is limited on the 6, so you may need to get compatible resolution scales.
Al.
Albert E.
