0 active members*
4,653 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Coreldraw, Sheetcam issues
    Mar 2017
    8
    How's everyone doing? I have a question(s)
    We use Coreldraw to Sheetcam to Mach3. When we draw what we want in Coreldraw and import it to Sheetcam, Sheetcam adds extra nodes and the drawing doesn't look as smooth as it did in Coreldraw. Curves aren't smooth, fonts seem to be the worst, etc.
    Yes we reduce the nodes. Yes we use SVG.
    Once we run the file on the table the cuts are jagged and not smooth.
    Why is Sheetcam adding extra nodes to the file from Coreldraw and why the jagged edges?
    I'm sure the issue is in the programming.
    Thanks in advance for all the help
    Sep 2008
    140
    Re: Coreldraw, Sheetcam issues
    Try exporting as a .dxf, I usually select an early version of AutoCAD.
    Larry
    Mar 2017
    8
    Thank you for the reply.
    Apr 2003
    540
    I get some strange things occasionally between programs also. Like metalfixer suggested, export as a different vector file type. I would try DXF, AI etc, and you quite often can get satisfactory results with one type over another. I personally found that I get errors occasionally with SVG and sometimes DXF imports into Sheetcam, but when I export as .ai files and load them in Sheetcam they are fine. Test them all, even export as different autocad version types if you have the option. You may find the combination that helps.
  1. Using CorelDRAW x6
    By 2_many_hobbies in forum Uncategorised CAD Discussion
    Last Post: 04-21-2015, 02:00 PM
  2. Re: Coreldraw x5
    By snateman in forum MetalWork Discussion
    Last Post: 01-16-2011, 10:06 PM
  3. coreldraw-->sheetcam-->mach3
    By Teknition in forum Waterjet General Topics
    Last Post: 11-25-2010, 04:50 AM
  4. Help with some Sheetcam issues
    By VTX in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-28-2007, 05:39 PM
