585,670 active members*
4,122 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > HELP! PlasmaCAM Doesn't Finish Initializing
    May 2013
    4
    When I initialize, the Z goes up, X and Y go to the top left corner as they are supposed to, then the motors go "twerk", "twerk", "twerk", continually until I turn the controller off. On the monitor, the window that indicates that it's still initializing remains. Here's a video link: https://youtu.be/xN1ZH9__1hc
    My machine was working fine until today, it is grounded to the earth, and I have installed the latest updates. Just in case it's pertinent, I also have Design Edge.
    Sep 2014
    112
    Re: HELP! PlasmaCAM Doesn't Finish Initializing
    Give those fellas in tech support a call. They'll get you going in no time. It looks like you have an older DHC machine, instead of the DHC2. Checking the wires on the z might be a good idea. I am curious, does the z move up and down when you use the keys on the CB.
    When you call plasmacam's tech, ask them about the the DHC2 upgrade kit that you can get for your older dhc system. It basically will make your into a new machine for a fraction of the cost.
    Good Luck Pal!
    JAG
    Jun 2018
    4
    Have you tried checking your microswitches? These are the ones that act as limit switches when the machine initializes and senses the home position. They are standard, cheap and easy to replace (located on the gantry & on/under the Y-axis motor). I’ve had to blow them clean from time to time with compressed air when cutting motion got glitchy. I have one of the older machines, purchased in 2003.
  1. Mazatrol T32 initializing
    By terra103 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-13-2023, 06:33 PM
  2. mach3 (?) - machine doesn’t finish the cut as it suppos to
    By thedemri in forum Mach Software (ArtSoft software)
    Last Post: 01-21-2013, 01:43 AM
  3. Z axis trouble while initializing?
    By Bradsky in forum PlasmaCam
    Last Post: 12-20-2011, 07:01 PM
  4. Battery change and initializing position _ NL series
    By aidenkim in forum Mori Seiki lathes
    Last Post: 08-26-2011, 02:28 PM
  5. Re-initializing Controller Software
    By Geof in forum Haas Mills
    Last Post: 03-18-2007, 06:54 PM
