584,808 active members*
5,362 visitors online*
    Mar 2014
    33
    Angry KIA V45 not changing tools
    Working on A Kia V45 Vertical that I had to reload the Parameters in. Has a Fanuc 0m-c control. Everything seems to work ok except the tool change cycle.
    The 20 tool drum will index to the correct tool pocket and then it alarms (PER 106) "Magazine needs zero returned". Pot will not drop and it just stops
    I'm pretty sure the tooling parameters are set up right. Tool designation etc.. Even in Maintenance mode the pot will not drop unless I manually drop it with the solenoid valve
    and then I can move the double arm. All switches are functioning. A/B phase and Home position(Pot 20) are changing in diagnostics. The machine does not use a macro but a Ladder sequence to change tools.
    Tried changing some of the D587 settings related to the tool changer but no luck.Have all of the orig.parameters set correctly. Banging my head against the wall on this one.
    Talked to Fanuc and they said this is a Kia side of the machine. Called Kia (Hyundai-Wia now) and no one there is supporting this old of machine any more (1997)
    Even when I index the tool drum manually I get an alarm light on the operators pendant (call Light) when it stops but no alarm on the alarm page.
    GRRRR!
    Any help would be great.
    Mar 2017
    Re: KIA V45 not changing tools
    If the drum is driven by a beta drive or power mate check parameter 11.0 under the pmm
    Mar 2014
    33
    I'll check it out. It used to work fine until the memory board crapped out and I had to reload all the parameters. It homes and the spindle runs and orients fine. Just the tool drum is acting weird Thanks
  1. Changing Tools on Fadal VMC 4020
    By coulombejerome in forum Fadal
    Last Post: 02-10-2015, 02:22 PM
  2. How are you changing tools? Multiple spindles? ATC? Manual?
    By Smertrios in forum DIY CNC Router Table Machines
    Last Post: 10-28-2013, 05:50 PM
  3. Problem with changing tools. (manual)
    By dlaery in forum BobCad-Cam
    Last Post: 07-27-2013, 03:05 AM
  4. low cost machine with changing tools automatic
    By wyl6362708 in forum Videos
    Last Post: 11-23-2010, 01:19 PM
  5. tools changing in eia program
    By andrejl in forum European Club House
    Last Post: 11-28-2007, 09:48 PM
