585,880 active members*
7,175 visitors online*
Results 1 to 1 of 1
    130-150W laser tube
    All Laser tubes were approved by CE and FDA.
    We are a Canadian company. Each laser tube will be tested again before sending out.
    GX– 1850
    Diameter: 80mm
    Rated Power: 130W
    Max.Power: 150W
    Application: Rubber, organic glass, leather, wood etc.
    Life Span: 6,000hours
    Warranty period: 6 months
    1 Stability: By using special equipment and import gas, the decomposition speed of the working gas has been effectively reduced so as to greatly prolong it’s working lifespan.
    2 Good mode (base film more than 95%) and small beam spot(3-5mm)
    3 High-power, for example, 130w laser tube can reach the maximum power that is 150w.
    4 In fact, Storing the laser tube for some time and testing the laser tube can reach the enough power. It proved that the laser tube is sealed very well.
    New producing laser tube is easy to have problem, since it was just tested after storing short time. If some laser tube is not sealed very well, the laser tube leaks gas gradually. The laser tube power will be decreased gradually. People could not found this problem even they test it again before sending out.
    5 Customer Support: If you have any questions about our product, please contact us by Email or Skype. My email address: [email protected], Skype: anna1127. We will give you the reply within 24 hours.
    6 Business: We would like to establish long business relationship with you, our company put the product quality as the first place.
    7.Shipping: We will send a new one freely if the tube is Broken during Transit.Please check the laser tube as soon as you receive it.
ID:	354807Click image for larger version.
    http://www.peakofglass.com/index.asp
    [email protected]
    [email protected]
