Hello,
I control a stepper motor with G201X gecko, the manual is here G201X / G210X REV-6 | GeckoDrive.
Before that I used other cheap driver that I control with a teensy 3.2 board. I use AccelStepper library to control the driver and it has a function that can disable the driver when is needed disableOutputs (). I just connect the enable pin of the cheap driver to the teensy and is working.
Now with gecko, I connect the same pin to the same digital pin of the teensy but is not getting the command. What should I do?
Thank you
