585,973 active members*
4,213 visitors online*
    Feb 2012
    117
    Curves not smooth
    I have a file I cut with the new uccnc and uc100 set up I bought. The curves are like short lines instead of nice arcs. I dropped the exact file into Mach3 and it cut the arcs the way it was supposed to. Same file, not altered. Also on a outer profile cut it would pause for a split second when it went from a straight line to an arc. Help please.
    Sent from my iPhone using Tapatalk Pro
    Re: Curves not smooth
    The default CV parameters are setup for metric use. I think you need to divide them by 25.4 for inches, which should give you much better results.
    Did the screenset update I sent you work OK?
    Feb 2012
    117
    Yes the new screen worked great. I'll try changing the cv adjustments. Thank you.
  1. tb6560 x axis is grinding y is smooth z is smooth im a newbie
    By Hotrod10 in forum Stepper Motors / Drives
    Last Post: 04-16-2015, 05:11 AM
  2. Replies: 25
    Last Post: 09-16-2013, 03:44 AM
  3. Faceting on smooth curves?
    By rewster in forum Benchtop Machines
    Last Post: 09-08-2013, 02:58 PM
  4. RPM vs. HP Curves
    By velocityxlrg in forum Tormach Personal CNC Mill
    Last Post: 05-30-2013, 02:43 PM
  5. Replies: 1
    Last Post: 11-08-2011, 05:30 PM
