585,954 active members*
4,650 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Post problem with "documentname" variable
Results 1 to 6 of 6
    Apr 2003
    1357
    Re: Post problem with "documentname" variable
    You are correct. This doesn't work.
    Nov 2013
    36
    Hi Dan,
    Thanks for your reply. Do you know of any alternate means of achieving the same end?
    Thanks!
    Apr 2003
    1357
    Unfortunately not. It's on the bug list so it will get fixed eventually. There are a few other variables I would like to see added as well.
    1) Stock to leave
    2) Step over
    3) Step down
    4) Strategy (climb, conventional or mixed)
    Nov 2013
    36
    Super. Those other additions would be great! Thanks for the response.
    Mar 2010
    66
    Just ran into this bug today.
    Hoping that the "documentname" bug fix will be coming soon.
    Would also love to see those variables Dan posted. They would be great for clarifying the output code.
    Leo
    Feb 2018
    7
    Hello All,
    I'm not sure if the document name is still a issue but I have change the following line in the post:
    *PROGRAM_START*
    N"lnbr" ; Program made on: "datetime"
    N"lnbr" ; Documentname: “documentname"
    Te vervangen door:
    *PROGRAM_START*
    N"lnbr" ;
    Program made on
    : "datetime"
    N"lnbr" ; Documentname : “pgmnr"
    After I change this I have the document name on top of my generated NC file
  1. modify post to add "next tool" variable after every tool change
    By allenp in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-22-2016, 08:56 PM
  2. Replies: 3
    Last Post: 01-04-2016, 10:11 AM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Replies: 2
    Last Post: 05-01-2010, 01:41 PM
