hello does somebody uses excel to program the cnc ? or something like that ?
i think there is something, but so far i have no experience with this ...
yes
hy mr bunny please, will you share an example ? what are the possibilites ? kindly !
i have used it for chamfering a cross hole on a swiss machine and a milled radius that included comp for the end mill
but it is only limited by the math that you can think up
the only thing that is required is to transfer/copy from exel to something like note pad to make sure the formulas do not transfer with it
here is one i use
HOLE SIZE MAT DIA HOLE LOC.
DEGREES INC 22.5 0.093 0.0465 0.375 0.1875 0.098 COMP FOR CUTTER 0.02
DEGREES Ytheory Ztheory Xtheory Machines X Y Z
0 0 0.0465 0.1875 X 0.2950 Y 0.0000 Z 0.1245
22.5 0.0178 0.0430 0.1867 X 0.2933 Y 0.0050 Z 0.1225
45 0.0329 0.0329 0.1846 X 0.2892 Y 0.0092 Z 0.1167
67.5 0.0430 0.0178 0.1825 X 0.2850 Y 0.0120 Z 0.1081
90 0.0465 0.0000 0.1816 X 0.2833 Y 0.0130 Z 0.0980
112.5 0.0430 -0.0178 0.1825 X 0.2850 Y 0.0120 Z 0.0879
135 0.0329 -0.0329 0.1846 X 0.2892 Y 0.0092 Z 0.0793
157.5 0.0178 -0.0430 0.1867 X 0.2933 Y 0.0050 Z 0.0735
180 0.0000 -0.0465 0.1875 X 0.2950 Y 0.0000 Z 0.0715
202.5 -0.0178 -0.0430 0.1867 X 0.2933 Y -0.0050 Z 0.0735
225 -0.0329 -0.0329 0.1846 X 0.2892 Y -0.0092 Z 0.0793
247.5 -0.0430 -0.0178 0.1825 X 0.2850 Y -0.0120 Z 0.0879
270 -0.0465 0.0000 0.1816 X 0.2833 Y -0.0130 Z 0.0980
292.5 -0.0430 0.0178 0.1825 X 0.2850 Y -0.0120 Z 0.1081
315 -0.0329 0.0329 0.1846 X 0.2892 Y -0.0092 Z 0.1167
337.5 -0.0178 0.0430 0.1867 X 0.2933 Y -0.0050 Z 0.1225
360 0.0000 0.0465 0.1875 X 0.2950 Y 0.0000 Z 0.1245
all i do is copy the machines x,y,and z (last 6 columns) to note pad then copy and past in to my program
you may have to neaten up the columns to make it look like it belongs in the program
hello again please, does someone have this cd ?
image is from osp300 instruction manual kindly !
i have the cd's with excel samples ( osp300 : lathe + mill ) too large to attach
if you wanna a copy, just buzz kindly !
Hey Kitty,
This does sound very interesting, wanna send me a copy?
Cheers
here you are : https://we.tl/UUru7YYM5G
Thank you Kittty... Good Cat.
i am glad to hear from you broby
i do not know when i will have time to explore those files
hello all attached *.xls file ( provided by Okuma dealer ) generates programs for the Renishaw
those programs are loaded automatically into the control
how can i do the same ( automatically loading programs ) ? kindly
I think you can use okuma thinc api but it requires some programming knowledge.
I don't know how to do.
"Imagination is more important than knowledge."
hey kurmay i was also thinking about API, but i dont have it yet.
there are many okuma applications, each one with its own specific, but none of them is loading programs; this does not mean that is not possible with API
the *.xls that i have does just that, so now i have to choose : learning API or learning macros in excel, and i really wanna shorten the learning cycle
i will just wait, maybe something happens ... however, i was thinking that maybe you have a magical floppy or something
hy okuma cnc excel samples : https://we.tl/aZINiyGay0
... about "raster to vector" : use corel draw man
... about "VB files" : i have no clue what they are
you are soooo loooooooost just kidding, is ok
