585,708 active members*
3,902 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > Plasma cam: Torch Fires in air. IHS not happening.
    Dec 2016
    6
    After a lot of noise issues and drama, i have finally started my Plasma Cam machine. But now I'm facing this new error when taking the first cutting. After initializing I proceed for cutting with 'Auto Cut control' enabled. But the torch just fires in the air, moves through the cutting path and it never comes down. As I'm a beginner on this machine, I'm not sure why this is happening. I am providing the link of the video and the settings below. I hope someone can help me out.
    https://drive.google.com/drive/folde...Gc?usp=sharing
    regards
    VARUN VASUDEVAN
    Mar 2017
    Re: Plasma cam: Torch Fires in air. IHS not happening.
    Varun,
    What plasmacutter are you using? All I can see that is out of spec is your cutting Height of 0.19mm, My Hypertherm65 run on 1.5mm on cutting 3mm steel like in your setup, have you tried enabelling Auto calibrate Z shift on next cut ?
  1. Gecko G540 Faults When plasma fires. PLEASE HELP!! I'm running out of time.
    By HIDesigns in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-15-2013, 02:03 PM
  2. How to wire a new plasma torch to plasma cam??
    By Bradsky in forum PlasmaCam
    Last Post: 04-05-2013, 12:26 PM
  3. newbie- torch fires on and off please help
    By cuttinloose in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-05-2012, 02:12 PM
  4. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
  5. CNC Plasma torch?
    By david01130 in forum Waterjet General Topics
    Last Post: 11-02-2010, 12:51 AM
