585,760 active members*
3,717 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > urgent please.. problem with THC or hypertherm plasma?
Results 1 to 6 of 6
    Unhappy urgent please.. problem with THC or hypertherm plasma?
    have a new plasma cutting with THC Chinese , but the plasma power source is hypertherm 200a,
    the cnc control unit is starfire brand
    and the machine doesn't function normal, " the problem we have, is when we have a drawing have more than vectors, and we click the start button, the torch start cutting with the plasma for some vectors, 2 or three vectors , then the plasma stops, moving stop. eroor msg on the starfire "ACR BK" and the torch going up.
    when i press again start then complete the drawing without the plasma ". and the next vector plasma come again.
    this same problem, with the same design same paramater same sheet, sometimes coming. sometimes not coming.
    anybody know how to fix this issue?, we have tried changing the software parameters alot, and all what we got is to set the parameters.
    hope you can help us with this, and attached also the pictures of the design. <br>there two works are for the same design same parameter same sheet 5mm carbon steel we use 50a electrode and nozzle. one time cutted ok without problem, second time come the problem and the torch just make hole for two vectors..
    https://f.top4top.net/p_4448p8u91.jpg
    https://a.top4top.net/p_444er3g82.jpg
    Thanks in advance
    Jul 2016
    660
    Re: urgent please.. problem with THC or hypertherm plasma?
    What kind of CAM software did you use? seems like a CAM program issue, can you post a sample drawing with exact size and measurement and the thickness of the metal material? I will try to program it myself then give you the code, does your machine have a USB port?
    Quote Originally Posted by KH0UJ View Post
    Yes my friend
    Give me your email i will send you dxf file. Then you make the code file i will test it.
    If works correct that mean software parameters.
    Machine have usb port right.
    Waiting for your email. Thank you for your help..
    Yes my friend
    I use Fastcam software.
    Jul 2016
    660
    Quote Originally Posted by habdulazez View Post
    Yes my friend
    pm`ed you my email sir
    Jul 2016
    660
    Post Re: urgent please.. problem with THC or hypertherm plasma?
    For the meantime you can test my sample code and see if it works on your plasma just copy / paste it on a notepad and rename it to Transformers plasma.tap
    Code:
    N5 (File Name = transformers KH0UJ is handsome)
    N10 (Default Plasma Post)
    N15  G91.1
    N20 G0  Z60.0000
    N25 G0  X106.6376  Y4.3735
    N30 G28.1 (Probe for Stock)
    N35 G0  Z0.0000
    N40 M3(PLasma On)
    N45 G4 P0.1000
    N50 G1  X139.4108  F60.00
    N55  X172.1840
    N60  X161.2108  Y38.0298
    N65  X139.4108
    N70  X117.6108
    N75  X106.6376  Y4.3735
    N80  X105.2117  Y0.0000
    N85 G4P0.10
    N90 M5 (Plasma Off)
    N95 G0  Z60.0000
    N100 G0  X82.8372  Y120.4146
    N105 G28.1 (Probe for Stock)
    N110 G0  Z0.0000
    N115 M3(PLasma On)
    N120 G4 P0.1000
    N125 G1  Y113.4146
    N130  X115.2108  Y131.3298
    N135  Y65.7298
    N140  X139.4108
    N145  X163.6108
    N150  Y131.3298
    N155  X195.9843  Y113.4146
    N160  Y20.3146
    N165  X182.6254  Y8.4004
    N170  X167.6713  Y44.9603
    N175  X139.4108
    N180  X111.1502
    N185  X96.1962  Y8.4004
    N190  X82.8372  Y20.3146
    N195  Y113.4146
    N200 G4P0.10
    N205 M5 (Plasma Off)
    N210 G0  Z60.0000
    N215 G0  X139.4108  Y71.9572
    N220 G28.1 (Probe for Stock)
    N225 G0  Z0.0000
    N230 M3(PLasma On)
    N235 G4 P0.1000
    N240 G1  X138.4310
    N245  X121.6577
    N250  Y141.4572
    N255  X115.2108  Y189.1232
    N260  X139.4108  Y171.1013
    N265  X163.6108  Y189.1232
    N270  X157.1638  Y141.4572
    N275  Y71.9572
    N280  X140.3905
    N285  X139.4108
    N290 G4P0.10
    N295 M5 (Plasma Off)
    N300 G0  Z60.0000
    N305 G0  X23.9363  Y161.1294
    N310 G28.1 (Probe for Stock)
    N315 G0  Z0.0000
    N320 M3(PLasma On)
    N325 G4 P0.1000
    N330 G1  X55.7456  Y140.1584
    N335  Y132.2584
    N340  X73.7534  Y115.2068
    N345  Y28.1068
    N350  X30.7297  Y65.9519
    N355  X23.9363  Y161.1294
    N360  X17.3407  Y165.4778
    N365 G4P0.10
    N370 M5 (Plasma Off)
    N375 G0  Z60.0000
    N380 G0  X24.6895  Y230.2654
    N385 G28.1 (Probe for Stock)
    N390 G0  Z0.0000
    N395 M3(PLasma On)
    N400 G4 P0.1000
    N405 G1  Y220.3826
    N410  X85.2299  Y182.9006
    N415 G4P0.10
    N420 M5 (Plasma Off)
    N425 G0  Z60.0000
    N430 G0  X29.2856  Y224.8538
    N435 G0  Z0.0000
    N440 M3(PLasma On)
    N445 G4 P0.1000
    N450 G1  X24.6895  Y230.2654
    N455  X85.2299  Y194.4179
    N460  Y183.0179
    N465 G4P0.10
    N470 M5 (Plasma Off)
    N475 G0  Z60.0000
    N480 G0  X35.9747  Y199.1522
    N485 G28.1 (Probe for Stock)
    N490 G0  Z0.0000
    N495 M3(PLasma On)
    N500 G4 P0.1000
    N505 G1  X31.5728  Y204.3351
    N510  X90.4287  Y169.4850
    N515  Y157.7153
    N520  X31.3309  Y193.9083
    N525  X31.5728  Y204.3351
    N530 G4P0.10
    N535 M5 (Plasma Off)
    N540 G0  Z60.0000
    N545 G0  X115.2108  Y189.1232
    N550 G28.1 (Probe for Stock)
    N555 G0  Z0.0000
    N560 M3(PLasma On)
    N565 G4 P0.1000
    N570 G1  X111.6016  Y191.8110
    N575 G4P0.10
    N580 M5 (Plasma Off)
    N585 G0  Z60.0000
    N590 G0  X53.7373  Y228.7882
    N595 G28.1 (Probe for Stock)
    N600 G0  Z0.0000
    N605 M3(PLasma On)
    N610 G4 P0.1000
    N615 G1  X103.3207  Y196.2617
    N620  X113.2667  Y142.1685
    N625  X54.5747  Y152.5325
    N630  X23.2932  Y174.2828
    N635  X4.0399  Y265.4724
    N640  X46.9141  Y253.7733
    N645  X53.7373  Y228.7882
    N650 G4P0.10
    N655 M5 (Plasma Off)
    N660 G0  Z60.0000
    N665 G0  X139.4108  Y215.7189
    N670 G28.1 (Probe for Stock)
    N675 G0  Z0.0000
    N680 M3(PLasma On)
    N685 G4 P0.1000
    N690 G1  X179.0310  Y245.4572
    N695  X140.3905
    N700  X138.4310
    N705  X99.7905
    N710  X139.4108  Y215.7189
    N715 G4P0.10
    N720 M5 (Plasma Off)
    N725 G0  Z60.0000
    N730 G0  X54.9403  Y270.2291
    N735 G28.1 (Probe for Stock)
    N740 G0  Z0.0000
    N745 M3(PLasma On)
    N750 G4 P0.1000
    N755 G1  X58.4106  Y257.8047
    N760  X63.1842  Y260.3071
    N765  X68.0586  Y262.6070
    N770  X73.0253  Y264.7002
    N775  X78.0755  Y266.5831
    N780  X83.2002  Y268.2524
    N785  X88.3905  Y269.7052
    N790  X93.6372  Y270.9387
    N795  X98.9311  Y271.9510
    N800  X104.2628  Y272.7401
    N805  X109.6229  Y273.3048
    N810  X115.0019  Y273.6441
    N815  X120.3905  Y273.7572
    N820  X138.4310
    N825  X139.4108
    N830  X140.3905
    N835  X158.4310
    N840  X163.8196  Y273.6441
    N845  X169.1986  Y273.3048
    N850  X174.5588  Y272.7401
    N855  X179.8904  Y271.9510
    N860  X185.1843  Y270.9387
    N865  X190.4310  Y269.7052
    N870  X195.6213  Y268.2524
    N875  X200.7460  Y266.5831
    N880  X205.7962  Y264.7002
    N885  X210.7629  Y262.6070
    N890  X215.6373  Y260.3071
    N895  X220.4109  Y257.8047
    N900  X212.5827  Y229.7774
    N905  X139.4108  Y185.6983
    N910  X66.2388  Y229.7774
    N915  X58.4106  Y257.8047
    N920 G4P0.10
    N925 M5 (Plasma Off)
    N930 G0  Z60.0000
    N935 G0  X247.7839  Y222.1541
    N940 G28.1 (Probe for Stock)
    N945 G0  Z0.0000
    N950 M3(PLasma On)
    N955 G4 P0.1000
    N960 G1  X254.1320  Y230.2654
    N965  Y220.3826
    N970  X193.5916  Y182.9006
    N975 G4P0.10
    N980 M5 (Plasma Off)
    N985 G0  Z60.0000
    N990 G0  X254.1320  Y230.2654
    N995 G0  Z0.0000
    N1000 M3(PLasma On)
    N1005 G4 P0.1000
    N1010 G1  X193.5916  Y194.4179
    N1015  Y183.0179
    N1020 G4P0.10
    N1025 M5 (Plasma Off)
    N1030 G0  Z60.0000
    N1035 G0  X4.0399  Y265.4724
    N1040 G28.1 (Probe for Stock)
    N1045 G0  Z0.0000
    N1050 M3(PLasma On)
    N1055 G4 P0.1000
    N1060 G1  X0.0000  Y270.2291
    N1065 G4P0.10
    N1070 M5 (Plasma Off)
    N1075 G0  Z60.0000
    N1080 G0  X179.0310  Y245.4572
    N1085 G28.1 (Probe for Stock)
    N1090 G0  Z0.0000
    N1095 M3(PLasma On)
    N1100 G4 P0.1000
    N1105 G1  X169.9623  Y242.3077
    N1110 G4P0.10
    N1115 M5 (Plasma Off)
    N1120 G0  Z60.0000
    N1125 G0  X254.8852  Y161.1294
    N1130 G28.1 (Probe for Stock)
    N1135 G0  Z0.0000
    N1140 M3(PLasma On)
    N1145 G4 P0.1000
    N1150 G1  X248.0918  Y65.9519
    N1155  X205.0681  Y28.1068
    N1160  Y115.2068
    N1165  X223.0760  Y132.2584
    N1170  Y140.1584
    N1175  X254.8852  Y161.1294
    N1180  X261.8982  Y165.7530
    N1185 G4P0.10
    N1190 M5 (Plasma Off)
    N1195 G0  Z60.0000
    N1200 G0  X241.3321  Y196.7751
    N1205 G28.1 (Probe for Stock)
    N1210 G0  Z0.0000
    N1215 M3(PLasma On)
    N1220 G4 P0.1000
    N1225 G1  X247.2488  Y204.3351
    N1230  X188.3928  Y169.4850
    N1235  Y157.7153
    N1240  X247.4906  Y193.9083
    N1245  X247.2488  Y204.3351
    N1250 G4P0.10
    N1255 M5 (Plasma Off)
    N1260 G0  Z60.0000
    N1265 G0  X233.7779  Y260.6225
    N1270 G28.1 (Probe for Stock)
    N1275 G0  Z0.0000
    N1280 M3(PLasma On)
    N1285 G4 P0.1000
    N1290 G1  X231.9074  Y253.7733
    N1295  X274.7816  Y265.4724
    N1300  X255.5283  Y174.2828
    N1305  X224.2468  Y152.5325
    N1310  X165.5548  Y142.1685
    N1315  X175.5009  Y196.2617
    N1320  X225.0843  Y228.7882
    N1325  X231.9074  Y253.7733
    N1330 G4P0.10
    N1335 M5 (Plasma Off)
    N1340 G0 Z60.0000
    N1345 M30
    Attached Files Attached Files
  1. problem with new chinese THC machine with hypertherm plasma
    By gaber2611 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-07-2022, 10:27 AM
  2. Replies: 0
    Last Post: 09-11-2015, 05:29 PM
  3. Replies: 0
    Last Post: 12-13-2014, 06:27 PM
  4. EMERGENCY - NEED HELP SOURCING UK SUPPLIER - URGENT URGENT URGENT
    By ApexLaser in forum Want To Buy...Need help!
    Last Post: 07-19-2014, 04:37 PM
