585,996 active members*
4,270 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > RF-45 Clone Mill > Another RF45 clone cnc inspired by the contributors on cnc zone
Results 1 to 7 of 7
    Sep 2011
    4
    Hi everybody, this is my first post on this forum.
    I have started the process of converting my small manual mill to cnc, and will try to post as many pictures as I can along the way. I hope that it will serve as an inspiration to anybody considering the task of converting a machine, and hopefully we can get enough information and ideas included to help each other out in the same way that I have picked up so much information from the other builds on this forum.
    Please feel free to comment on the progress, comments, ideas and positive criticism go a long way to prevent costly mistakes!
    Regards Steven
    Aug 2006
    671
    Re: Another RF45 clone cnc inspired by the contributors on cnc zone
    looks like you've got a bit of cleanup work ahead of you too
    Keep us posted. These are very capable little machines when done correctly.
    Sep 2011
    4
    Thanks cs900, I have stripped apart the whole machine already and given it a good cleanup!
    I also milled all of the x and y oil grooves and feeding holes for them, will post some pictures when I get a gap. The ballscrews and extra nuts have all arrived too, just need to pack the balls into the anti backlash nuts and make up some sort of holders for them.
    I am currently busy with the frame and designing the chip/coolant tray with the idea of housing the coolant tank directly underneath the machine, allowing all the water and shavings to be washed into a removable tank.
    Sep 2011
    4
    A few pictures of the progress so far.Attachment 355926
    Attachment 355930
    Jun 2016
    80
    Steven,
    I'm glad to see your machine cleaned up so well. In the first picture you posed it looked kinda rusty, but I guess it was mostly grime.
    What type of axis motors do you plan to use, and what control software?
    Looking forward to following your build. Everyone seems to take a different route with these machines so there is always a lot to be learned. I hope you have as much fun with this build as I have had with mine!
    Kurt
    Sep 2011
    4
    HI Kurt,
    Thanks, I had quite a time to get it clean! It is in quite good condition except for the bed, which I skimmed clean at work. I also milled in some coolant drain slots at the same time.
    I will probably run regular stepper motors on mach3 to get going, though I'm keen to try the Linux platform.
    Currently working on the coolant tray and the ballscrews mountings and couplings.
    Apr 2017
    Hi Steven
    Looking good. Keep the updates coming.
    I have also started a conversion on an original Rong Fu 25, 1976 year model with round post.
    Henri
    Kempton Park
    Sent from my SM-J100H using Tapatalk
  1. Need Info to CNC my RF45 Clone
    By elalto in forum Benchtop Machines
    Last Post: 01-11-2014, 03:12 AM
  2. What RF45 clone should I get?
    By Nigel Tufnel in forum Benchtop Machines
    Last Post: 12-03-2013, 06:24 AM
  3. RF45 clone CNC conversion
    By GMitchell in forum Uncategorised MetalWorking Machines
    Last Post: 09-08-2009, 05:50 AM
  4. RF45 clone with a DC motor
    By hdj80 in forum Charter Oak Automation Support Forum
    Last Post: 05-29-2007, 11:01 AM
  5. X3 or RF45 clone?
    By logjammer in forum Benchtop Machines
    Last Post: 12-14-2006, 03:34 PM
