585,705 active members*
3,924 visitors online*
Results 1 to 12 of 12
    Apr 2015
    77
    BDS4 overcurrent
    Hello,
    The Z-axis drive in my '95 Arrow 750 is throwing an overcurrent alarm.
    I have, in steps, disconnected the motor, replaced the two capacitors on the output and replaced the igbt module.
    Still it claims 'overcurrent'.
    Is there anything else I should take a look at? Software reset possibilities?
    Any hints are much appreciated.
    Regards
    Apr 2015
    77
    Re: BDS4 overcurrent
    I have found a simplified scheme tor the unit - could it be that the current limit pot is acting up?
    Apr 2015
    77
    -Update-
    Got in touch with MAG who were helpful enough to write me a measuring procedure - excellent service right there!
    I went with it and found that the output transistor(s) are just fine.
    I also interchanged the Z and Y drives to verify that the fault still occur at the current drive.
    Next thing will be to check and change the rest of the capacitors on the controlboard - I still have no detailed scheme for the unit, so this will be a blast...
    Apr 2015
    77
    Apparently the cap situated at #318 right between the aluminum coolers in the middle of the main pcb were shot... Ordering in fresh new caps, and hopefully the fat lady will sing again.
    If not ... Well... then I guess I'll have to sell a kidney and buy a refurbished one.
    Too exciting, this!
    Sent fra min SM-G900F via Tapatalk
    Sep 2010
    1765
    Good sluthing. Did that fix it?
    Email me if u want typical rpr, replacement, and kidney prices.
    Sent from my SM-G900V using Tapatalk
    Apr 2015
    77
    Quote Originally Posted by mike_Kilroy View Post
    Hi, Mike!
    I have caps on order - they are somewhere in the snailmail atm.
    Will ofcourse post pictures from the BDS4 resurrection party - or funeral...
    I'll get in touch if things don't work out - thanks!
    Sep 2010
    1765
    more suspect if faulty detection circuit are the caps in the circuit: 411 (1000pf), 367 (.1ufd). detection op am (comparator) is 369. Wierd scheme, but we watch the DC bus to detect overcurrent! one side of comparator held at dc bus + with 4700pf, other side of comparator input held at bus + withi .1ufd cap... timing circuit if bus dips too fast.
    course it appears your 318 is in the middle of our 3 voltage regulators; we bring in raw +10, +/-18vdc and regulate on board down to +5 & +/-12vdc in this section... if those voltages are not regulated right, all bets of course are off...
    let us know how you do!
    Apr 2015
    77
    I managed to remove the coolers without breaking the board. Win!
    On the picture one can see there has been some pesky electrolyte seeping out from #318 and downwards to the +5v regulator with friends. One of 318's legs still present - it snapped of easily due to corrosion.
    Looking forward to fit the new guys!
    Apr 2015
    77
    Fresh caps mounted - still overcurrent alarm on powerup. :violin:
    Next thing will be to rule out the SMD-capacitors mike_Kilroy referred to; #411 and #367. :stickpoke
    Apr 2015
    77
    Got the smd-caps today and soldered them right in. 1nF on #411 and 100nF on #367. Guess what!?
    Yeah... overcurrent alarm
    I've tried to trace the B+ to the comparator but it seems to be a resistor only here - marked '1002'.
    Component #415. Need a kidney?
    Apr 2015
    77
    Got rid of the overcurrent alarm!
    A couple of resistors in the measuring circuitry were way off spec. All good now!
    Thanks a bunch for pointing things out, Mike Kilroy! Don't know how to thank you properly, but in the meantime please accept these dazzling flowers;
    Oct 2019
    you need remplace irs2110 the 3 this chip comand the toshiba power mosfet
  1. Kollmorgen BDS4 206 23 possible failure
    By JFYM88 in forum Cincinnati CNC
    Last Post: 07-17-2015, 02:36 PM
  2. BDS4 OverSpeed Fault,
    By dyakush in forum Cincinnati CNC
    Last Post: 04-07-2014, 02:30 AM
  3. Arrow 500, AC2100, BDS4 Overspeed Fault
    By dyakush in forum Haas Mills
    Last Post: 04-05-2014, 06:35 PM
  4. Overcurrent Detector
    By M.RISHIKESH in forum CNC Machine Related Electronics
    Last Post: 07-31-2013, 03:01 PM
  5. VF-2 overcurrent on Y axis
    By coalstove in forum Haas Mills
    Last Post: 08-03-2006, 08:32 PM
