586,011 active members*
4,215 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > WATER CHILLER CW5000 COOLING FOR LASER ENGRAVER/CUTTER
    CW-5000 Water Chiller(AC110V or 220V)
    this unit controls the temperature of the laser tube cooling water and prevents laser operation
    if water flow fails or chiller is left off.
    Compact design with ±0.3'C temperature accuracy
    Compressor delay circuit, over-current protection
    Over-heat temperature alert, water flow protection
    CE certified
    Specification
    Cooling Power: 692W
    BTU: 2361 BTU / h
    Input power: AC 220V, 50Hz
    Current; 2.1A
    Compressor power: 3/8HP, 305Watt
    Freon: R134a
    Pump power: 30W
    Lift (cut off) : 10m (33ft)
    Rate: 10L/min, 158GPH
    Ambient Temp.: ≤ 35 ' c
    Chilled Water Temp. 8~30'C
    Dimension:550×280×430mm
    WATER CHILLER CW5000 COOLING FOR LASER ENGRAVER/CUTTER | eBay
    Re: WATER CHILLER CW5000 COOLING FOR LASER ENGRAVER/CUTTER
    up up up
  1. aquarium water chiller for laser?
    By fyrebug in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-30-2021, 06:54 PM
  2. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  3. Water chiller Cw3000 & CW5000 Manual and wiring diagram
    By Gweikelasers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-03-2014, 08:15 AM
  4. USD350--Water chiller CW5000 for 60w-100W CO2 laser machine
    By Sino-waterjet in forum News Announcements
    Last Post: 05-12-2014, 09:46 AM
  5. WANTED: Laser cutter air assist head & Water chiller (for cheap)
    By mowcius in forum Want To Buy...Need help!
    Last Post: 07-20-2012, 12:16 AM
