586,005 active members*
5,088 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Is it possible to disassemble/reuse these Heidenhain connectors?
Results 1 to 6 of 6
    Nov 2012
    29
    I just wanted to check before I cut them.
    Jul 2016
    660
    Re: Is it possible to disassemble/reuse these Heidenhain connectors?
    one thing for sure, they did not solder it with that metal enclosure installed, I think you can find a way to open that and resolder every wires on it, cut them shorter of course then resolder everything and re use it.
    Nov 2012
    29
    I know that they were assembled after soldering, but the fact that I cannot find any kind of release tab or setscrew makes me think that they weren't designed to come apart after assembly.
    Apr 2016
    16
    Found on another forum:-
    Figured it out eventually,
    I had to remove the clamp at the end of the plug preventing the wires from getting pulled out
    then screw the plug back into the socket
    then with a spanner (19mm) the rear can be unscrewed (normal RH thread)
    after removing again from the socket, the plug can be separated and is ready to be soldered.
    I did try to post a link directly to the forum, but it appears to get blocked.
    Anyway, hope this helped.
    Nick.
    Nov 2012
    29
    Quote Originally Posted by nick952 View Post
    Nick.
    Man! Do I ever owe you one! Thanks a ton.
    Dec 2011
    99
  1. Mill Upgrade Options - Reuse existing DC Brush amps and servos?
    By Marty_Escarcega in forum Centroid CNC Control Products
    Last Post: 10-07-2016, 06:58 PM
  2. Replies: 4
    Last Post: 04-04-2015, 04:03 PM
  3. Saving code for easy reuse somehow?
    By facegarden in forum Mastercam
    Last Post: 04-24-2009, 01:46 AM
  4. Reuse the waste oil
    By beruren in forum Environmental / Alternate Energy
    Last Post: 03-04-2009, 03:58 AM
