585,959 active members*
5,035 visitors online*
IndustryArena Forum > CAD Software > Solidworks > How to connect two faces
    Jan 2012
    55
    Hello,
    I made a part file and created two solidbodies completely separate from one another (I know it's not a good way to make my part). But now it raised a good learning curve for me how do I move both parts together and have them connect together using the faces of each part. It would be similar to mating the two but they are in the same drawing file.
    Dale
    Jan 2014
    16
    Re: How to connect two faces
    Create two separate part files from the single multibody part file by selecting each in the design tree | save body.
    Create an assembly | insert each part file | mate the faces and anything else you wish.
    Use the join command to join the assembly into a single part file.
    Or...model again...correctly.
    Jun 2008
    562
    Quote Originally Posted by dkrenfrow View Post
    Hello,
    Dale
    There are a couple of ways, create 2 cofigurations of the part. One configuration for each body, either suppress or hide the other body in each. Create a assembly with the 2 of the parts(one for each config.). Add your mates as needed.
    Feb 2009
    311
    It's more conventional to do this sort of thing in an assembly, but doing it in a single part file is perfectly valid as well. Most likely what you want to do is to move one body into place so that it matches up with the other. The move body command should let you do that, and you can even use simple mate constraints (but only the simple ones) just like in an assembly.
    C|
  1. Camworks machinable faces
    By itolond in forum CamWorks
    Last Post: 04-03-2014, 07:29 AM
  2. restricting faces
    By pejaer in forum Tormach Personal CNC Mill
    Last Post: 07-14-2012, 05:22 PM
  3. CAM for multiple faces
    By Woody242 in forum Dolphin CAD/CAM
    Last Post: 02-02-2011, 02:16 AM
  4. enroute for curved faces
    By ninehigh in forum EnRoute
    Last Post: 11-29-2010, 09:33 PM
  5. animal faces
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 11-29-2009, 06:36 AM
