586,011 active members*
4,212 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Glass Scales with Resolver
    Mar 2008
    683
    Howdy,
    Does anyone here have experience with glass scales on a Fadal. I have acquired another Fadal, a 1996 4020. The machine ran fin with the scales unplugged. For 'fun' I plugged in the scales and ran through the CS procedure. The machine attempts to zero the scales but I get a "SCALE ERROR" so there's no luck using the scales and obviously the reason why they were disconnected.
    Thanks in advance.
    Mar 2008
    683
    Re: Glass Scales with Resolver
    Just to update. I have removed the glass scales. They were filthy. And the guru Dave DeCaussian suggests they are not worth having them. Now on to another problem...
    Oct 2013
    84
    Quote Originally Posted by warrenb View Post
    WarrenB, How did you remove the glass scale? I'm having an issue with my X axis direction.. can i just unplug something or change some parameter without removing the physical hardware under the table? Thanks!
    Sep 2017
    1991 Fadal 6030HT CNC88 w/ xy scales here. Open loop vs closed loop servos is what you guys are doing. Unplug the scales and set backlash parameters for worn out screws. The machine will the turn the screws "x" number of turns +/- whatever you set in the backlash parameters. In contrast, plug the scales in and set backlash parameters to 0 (zero) for worn screws. The scales read actual position and the screws then compensate in real time.
    Jul 2005
    17
    Just a reach Out. I am interested in purchasing any of the Glass Scale components. Covers, cables, boards, and glass scales, even if they are not working. I have two 4020s, a 3016, and a 2216 with extended Z and a tr65. One of my 4020s has the glass scales, which I had to replace the x-axis Heidenhain scale, and now it works great. I would like to convert my remaining Fadal's if possible.
  1. DRO - Glass scales or cheap Chinese digital scales?
    By strandbygaard in forum Benchtop Machines
    Last Post: 04-05-2010, 03:01 AM
  2. Glass scales as encoders
    By dcprecision in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2010, 06:51 PM
  3. Glass scales on 8030
    By mstorkamp in forum Fadal
    Last Post: 07-29-2009, 07:35 PM
  4. glass scales
    By Matt Sachs in forum Linear and Rotary Motion
    Last Post: 03-19-2009, 09:45 PM
  5. Hiedenhain glass scales
    By davesnd in forum CamSoft Products
    Last Post: 02-22-2009, 11:46 PM
