Hi Im new to parametric programming (Custom Macro). Im not sure if our controller is parametric programming compatible (Quictech with Syntec 900T controller). I read somewhere that if I type in the command #101=1 and the controller doesn't issue an alarm, then the controller is compatible. Is this correct? I did this and there was no alarm.
More importantly, how can I find out which system variables are linked to which offsets? (eg. System variables from the #2000 series relate to tool length offset values.) - Not sure if this is correct.
I would like to create a parametric program to set the tool lengths automatically.
Any help, pointers and info would be appreciated.
