Hello,
Can someone translate exactly how to follow the instructions on the G201X product site regarding Reducing RF Interference.
They say:
Use a shielded 5-conductor cable for your motor to drive connection; 4 of the wires go to the motor leads while the 5th goes to the motor case. Return the motor case wire to the drive’s power supply ground connection. Ground the shield to your electronics control box at the control box end only, leaving it disconnected at the drive end.
So I have the following configuration:
http://www.geckodrive.com/geckodrive...ves/g201x.html
high torque stepper motor & CNC Stepper Motor- StepperOnline
Switching Power Supply 350W 60V 5.9A for CNC Router Kits 115V/230V S-350-60|DE064|Power Supplies
Where should I connect the shield and the 5-th wire? To the main power supply ground? or to V- of the power supply?
Is it ok to connect the 5-th wire to the screw of the case?
Thx
