585,987 active members*
4,178 visitors online*
Results 1 to 6 of 6
    Mar 2017
    2nd Ethernet Hanwah w/Fanuc 18i
    is it possible to add a second Ethernet port to the Fanuc controllers?
    We have a situation where we are adding a hp cool-tech power pump 1200 series high pressure pump and it requires the embedded port to function. We are already using the embedded port for FTP and Machine Metrics to keep track of production, so I was wondering if there was a way to add a second port?
    May 2016
    30
    Re: 2nd Ethernet Hanwah w/Fanuc 18i
    Just connect the pump to any Ethernet port on the same network that your machine is on, It will work, trust me..
    Mar 2017
    Lightbulb Re: 2nd Ethernet Hanwah w/Fanuc 18i
    Quote Originally Posted by PEGBOARD View Post
    There are complex instructions on how to configure the fanuc controller and part of that is a specific ip address that looks suspiciously like an autoconfiguration address (169....). I don't see where I can change the ip address of the pump to make it compatible with our network but thank you, you have given me something to shoot for. Perhaps I can sign into the pump with a laptop or something to change its interface settings? Also I am concerned that the myrid changes will interfere with the FOCAS settings and prevent the machine form outputting metrics on the FOCAS port.
    Feb 2009
    6028
    To answer your initial question, yes you can add another port. Not a real cheap solution, hardware comes from fanuc. I think the price for the high speed port on our last retrofit was ~1200.
    Sent from my SM-T813 using Tapatalk
    May 2016
    30
    [QUOTE=econcepts;2023146]There are complex instructions on how to configure the fanuc controller and part of that is a specific ip address that looks suspiciously like an autoconfiguration address (169....). I don't see where I can change the ip address of the pump to make it compatible with our network but thank you, you have given me something to shoot for. Perhaps I can sign into the pump with a laptop or something to change its interface settings? Also I am concerned that the myrid changes will interfere with the FOCAS settings and prevent the machine form outputting metrics on the FOCAS port.[/QUOT
    Looking at your setup is your focus port hard wired or a wireless setup.
    Mar 2017
    its hardwired, but the problem has been solved.
    We used a brainboxes industrial Ethernet switch - Industrial Ethernet 4 Port Switch DIN Rail Mountable - SW-504 - Brainboxes - Industrial Ethernet IO and Serial and installed it inside the controller using the 24V bus. Ports as follows: 1. Shop Ethernet, 2. Pump, 3 Machine, 4 Machine front panel port (for a potential laptop connection or for a wth we happen to have another port)
    I then reprogrammed the PLC in the pump with their software to a compatible address (from the comfort of my workstation, I might add), switched the machine back to a compatible address and set the pump to use the new address of the machine, it all seems to work great.
  1. Ethernet Fanuc 18i-TB
    By ProToZyKo in forum Fanuc
    Last Post: 03-14-2019, 02:42 AM
  2. Fanuc 0i-MD - DNC over Ethernet
    By popex in forum Fanuc
    Last Post: 07-12-2015, 10:08 AM
  3. Hanwah xd20 brake slipping
    By Swissmiss in forum Trade Shows / Webinars / Other Events
    Last Post: 11-11-2014, 02:07 AM
  4. Fanuc DNC with Ethernet
    By elab.ess in forum Fanuc
    Last Post: 07-14-2014, 11:41 AM
  5. Hanwah ML12 & Iemca Genius 112???
    By MX1 in forum CNC Swiss Screw Machines
    Last Post: 12-23-2011, 10:08 PM
