585,712 active members*
4,099 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > New Benchtop Milling Machine One-Shot Oil Lubrication System Guide-Version 1 (e-book)
    Feb 2017
    14
    Post New Benchtop Milling Machine One-Shot Oil Lubrication System Guide-Version 1 (e-book)
    We are pleased to announce that a new Benchtop Milling Machine One-Shot Oil Lubrication System Guide-Version 1 e-book has just been added to our product line.
    The Guide is an illustrated design, installation, operation, and maintenance guide that contains all of the information necessary to enable the proper design, installation, operation, and maintenance of a benchtop milling machine, automatic, “one-shot”, oil lubrication system.
    The information provided in the Guide is relevant to benchtop milling machines of the type that have all of the following features:
    • A table saddle that has female dovetail X-axis stationary ways and female dovetail Y-axis moveable slides.
    • A column saddle that has female dovetail Z-axis moveable slides.
    • Adjustable and tapered X-, Y-, and Z-axis gibs.
    • A hollow, box type column with front slot.
    • Either a fixed head or a rotatable head.
    Examples of such milling machines include the:
    • Grizzly G0704, and G0759.
    • Optimum BF16Vario, BF20Vario, BF20LVario, BF20LD, and BF30Vario.
    • Warco WM14, WM16, and WM18.
    • Weiss WMD16V, WMD16VA, WMD20V, WMD20LV, WMD25V, WMD25LV, WMD30V, and WMD30LV.
    • Rong Fu RF-45.
    Please note that the above are just some examples of particular milling machines that the Guide is relevant to. There are many other machines that the Guide is also relevant to.
    If you have a milling machine of the type described above and you wish to install a one-shot oil lubrication system on it but you’re not sure how to go about correctly designing, installing, operating, or maintaining such a lubrication system, the information provided in the Guide will save you a lot of time and hassle.
    Information contained in the Guide
    The New Benchtop Milling Machine One-Shot Oil Lubrication System Guide-Version 1 e-book includes over 250 high-quality drawings and photographs. Additionally, it explains in detail:
    • Various installation configurations for the system.
    • How to determine the oil requirement for each lubrication point of the machine that is to be lubricated by the system.
    • How to determine the correct flow rates for the lubrication system meter units that are connected to the lubrication points.
    • The correct methodology to select an appropriate lubricator pump for the lubrication system.
    • How to layout the oil grooves for the various slideways and gibs of the machine.
    • How to calculate the correct dimensions of the oil grooves.
    • The correct profile shape of the oil grooves for inhibiting the scraping of oil from bearing surfaces.
    • How to machine an oil groove that has the correct profile shape.
    • Options for machining the oil grooves and other features for the system. (One option is to machine them with the machine on which the system is being installed.)
    • How to deburr the machined slideways and gibs.
    • Installation options for various parts of the system.
    • How to use some simple and inexpensive tools to cut, straighten, and bend aluminium tubing.
    • How to install aluminium and nylon tubing.
    • A suggested installation and commissioning procedure for the system.
    • How to operate the system so that each lubrication point receives the correct amount of oil.
    • How to maintain the system.
    • An example of a system installed on a machine that includes glass scales. The system and scales are installed such that they do not limit the head travel or the table travel of the machine.
    For additional information regarding the Guide, please click on the link above.
    If you have any questions regarding the Guide, please free to contact us.
    Lubrication Engineer
    Sep 2011
    60
    Re: New Benchtop Milling Machine One-Shot Oil Lubrication System Guide-Version 1 (e-b
    Nice book,
    USD prices would be nice.
    James L
  1. One shot oiler for BF20 milling machine
    By gofa23 in forum Benchtop Machines
    Last Post: 08-11-2019, 11:09 PM
  2. TMC1000 Benchtop CNC Milling Machine Like New!!
    By hydropro in forum For Sale Only
    Last Post: 02-21-2015, 09:50 PM
  3. Looking for a New Benchtop Milling Machine
    By Truggys_Suck in forum Benchtop Machines
    Last Post: 08-14-2014, 07:06 AM
  4. Best Benchtop Milling Machine
    By Engineer123 in forum Benchtop Machines
    Last Post: 05-22-2012, 07:48 PM
  5. One shot lubrication?
    By 79TigerPilot in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2008, 05:06 AM
